Interrupt on 2 UART
Mathy
Has thanked: 30 times
Been thanked: 33 times
Interrupt on 2 UART
Post by Mathy »
Hi everybody :)
I have a 18F6527 and I use the two UART. I would like to use the two uart in interrupt mode.
With only one, it works very well ( I juste have to add "set_bit(intcon, PEIE);" at the top of my program ).
I made some modification on the FCD file to add the second interrupt but if I use the two of them in my program, neither works :(
I attached my FCD file if somebody can have a look.
Thank you for your help !
18F6527.fcd
(12.37 KiB) Downloaded 293 times
Re: Interrupt on 2 UART
Your modified FCD looks ok to me. Something you could try is to manually perform a character read from both UART components before enabling the interrupt. This should clear any potential errors on the bus and hopefully allow the interrupts to start working.
Let me know how you get on.
Mathy
Post by Mathy »
Hi Benj,
I already performed a character read from both UART without any sucess.
If I delete those character read and if I add this code at the top of the program.....it works !
st_bit(intcon, PEIE);
st_bit(rcsta, SPEN);
st_bit(rcsta, CREN);
st_bit(rcsta2, SPEN);
st_bit(rcsta2, CREN);
8)
