Access denied to a FCF file ????
ksor
Post by ksor »
I have made some changes to the example file coming with version 4:
4. Four digit counter using timer interrupt.FCF
The changes is:
I've added 4 X Led7Seg() and wired them up as common cathode and connected them.
Then I saved the filed and tested the function - works fine "on screen" in Flowcode.
I then configured to 16F628A and no WatchDog and compiled to ASM.
Loaded the ASM-file into MPLAB and simulated a run - BUT teh simulation just quit because the program counter was outside valid address.
That's the problem 1) - why ?
Problem 2) is that now I can't open my FCF file - Access denied - why ?
(Another test program of mine can't see no locks on the FCF-file)
The FCF-file is attached
Access denied to this file
(18 KiB) Downloaded 235 times
Best regards
KSor, Denmark
Has thanked: 114 times
Been thanked: 422 times
Re: Access denied to a FCF file ????
Post by Steve »
This file seems to have some data missing from it. Is this another file you have been using with the demo version whilst trying to circumvent the demo version restrictions?
ksor
Post by ksor »
No - I un-installed the demo version - deleted ALL in regestry - rebooted and installed the new version.
And started to change the project.
Best regards
KSor, Denmark
Post by Steve »
I've tried to find the problem with this file without success, so I'm afraid you'll need to start again.
Your case does seem to be unique - no-one has reported any similar problems before. If you can provide a specific set of steps for us to replicate this problem here, we will try it out. But if we cannot replicate the problem, then I doubt we will be able to solve it for you.
ksor
Post by ksor »
OK - I'll try to convert the original fcf-file again.
Best regards
KSor, Denmark
