Error in flow block name
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Post by jadiflow »
The interrupt on change block in flowcode is always named: 'Enable PORTB' even if another port, like portA, is enabled.
Many PICs allow a mix of portA and portB pin interrupt-on-change to be enabled, so it's better to either reflect the port pins enabled in the block name, or to name this block port-neutral to avoid confusion ;-)
jan didden
Linear Audio
Has thanked: 114 times
Been thanked: 422 times
Re: Error in flow block name
Post by Steve »
Good point, Jan.
We intend to revamp the way interrupts work in V5.
