The interrupt on change block in flowcode is always named: 'Enable PORTB' even if another port, like portA, is enabled.
Many PICs allow a mix of portA and portB pin interrupt-on-change to be enabled, so it's better to either reflect the port pins enabled in the block name, or to name this block port-neutral to avoid confusion
jan didden
Linear Audio
