Whilst trying to programme and compile the following attached file, I am stuck with a compiler error, works fine on Simulation
Please advice.
File name: D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c
Generated by: Flowcode v4.3.7.63
Date: Thursday, January 13, 2011 21:47:37
Licence: Professional
Registered to: narayanaindana
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "data logging can manipulate.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\pp.exe "D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\include -d _PIC16F88 -la -c2 -o "D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.pp" -v -d _BOOSTC -d _PIC16
D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c(1714): error: missing right paren
D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c(1714): error: error in 'if' expression
D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c(1714): error: missing semicolon
D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c(1258): error: failure
failure
Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
FINISHED
