EB-063 connection RF-macro
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
Post by saschech@gmx.de »
Hello Team
In the ext properti.. thera are software and hardware connection.
in software-conn. i can set all io-pins to ports i want.
in hardware-conn. i can set only the cs-pin and the fsel-pin to all ports.
Question:
Use the rf-macro the sck2,sdi2,sdo2 pins ? >> 30F5013
because many chip`s have also sck1,sdi1,sdo1 pins.>>30F6012A
Regards Wolfgang
(46.23 KiB) Downloaded 634 times
Re: EB-063 connection RF-macro
Hi Wolfgang,
When the component is in hardware mode it will default to SPI peripheral number 1.
E.g. sck1,sdi1,sdo1 pins
You can re-assign the SPI peripheral if you wish by using the custom code feature to change the following definition.
#define MX_RF_SPI_HW %a //SPI Hardware or Bitbanged Port Control
to
#define MX_RF_SPI_HW 2 //SPI Hardware Peripheral 2
saschech@gmx.de
Has thanked: 1 time
Hello Benj
I have understand your answer and i now the costum-code-macro
but i have a big problem to use it in praxis
is there a example for rename the 3 spi1 pins to spi2 because i use the int0 (is the sck1-pin)?
regards Wolfgang
Hello Wolfgang,
Yes as I seaid before switching between peripherals is fairly straightforward.
Select the RF component on the panel and click the custom code button in the panel properties pane.
Then select the defines function and click edit.
Find the line near the top of the defines.
and change it to match this.
Click Ok and hopefully that's job done.
saschech@gmx.de
Has thanked: 1 time
Hello Benj
Thank you again!!
I was thinking a complete other one..... "custom" in the Misc-tab ..... oh,oh
it is fairly straightforward to change!
Is these change only for the project or for ever in a file?
Regards Wolfgang
Hi Wolfgang,
The change is only on a project basis. If you need a more permanent solution for other programs then you can either export the customized component and then import into programs that need the mod, (this can be done via the customise window) or you can manually edit the component C file to make the change permanent.
