MX027 - Controlling a Servomotor with timer0 interrupt.
Article: https://www.flowcode.co.uk/old_site/resources/get ... php?id=453
If you have any questions for the author or comments on the article, please post them below.
Re: Controlling a Servomotor with timer0 interrupt.
I could write a tutorial on controlling multiple servos with just a timer0 interrupt similar to above post
It should be straight forward to control multiple servos for instance:
Robotics, RC planes, cars boats etc. just using the 16F88 that arrived with programmer EBlock EB006 (without the LCD)
If anyone is interested in such an article please let me know.
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Hi Martin
That simulator program is impressive. Think I'll be registering that myself,especially looking at the cost. Did see you originaly posted about it a few days ago.
Did find using your program (above) with internal osc selected, the LCD didn't display anything, but changing to xtal and recompilling the hex code it all worked fine.
I'll try it on real hardware later.
Thanks for sharing that with forums
Hi John.JohnCrow wrote: Did find using your program (above) with internal osc selected, the LCD didn't display anything, but changing to xtal and recompilling the hex code it all worked fine.
Not at all. I have only used the simulator to give a screen shot of the waveform.
I tried with my hardware before posting the tutorial and LCD worked as expected with the configuration file set to INTRC as Port I/O
What you said is interesting, as I have just altered configuration to HS sent to chip and still works 100%
How odd?
But if I do experience what you have stated, at least you gave work around.
Thanks for that.
Hope tutorial is wrote in a way in which it gives an understanding.
I have never used a servo before, so on Saturday, I set my HPACT board up for the 1st time, and learned how to drive servos from
TEFWS.pdf which is posted here:
http://www.matrixmultimedia.com/mmforum ... 177#p11066
So im not an expert with servos, but probably got a good enough of an understanding now to answer any questions on driving them
- JohnCrow
Hi Martin
I was refering to the Realpic simulator program not showing on the LCD. Ive not had chance to try it on real hardware.
I dont have the HPACT board, but I do have the servo eblock and a couple of servos
Ah sorry I must of miss read your post.
Same applies the simulator. LCD works fine, if configuration was internal OSC or not. I don't think the simulator uses the configuration settings within the hex file anyway.
However to find that it does not matter for real hardware if internal or HS is selected was interesting, so I'm glad ive misread your post
A tip I find works when your setting up LED's, LCDs etc for the connections, is use the next follows up/down function.
Any servo should work, and in the tutorial, I have included a bit on changing the formula to change the timing of the pulses.
Useful if pulse duration is different from the 1.0ms to 2.0ms limits.
Forgot to add....
Although I am also impressed with simulator, and I pointed out a bug which meant IOC did not work, they did produce an update.
So IOC works on V1.3 as intended.
Since then they don't appear to reply to any emails (although not about bugs, but suggestions).
Their support is NOWHERE near as good a Matrix Multimedia. Don't even come close!
They don't even have a forum you can respond in.
But overall is worth purchasing since it runs in real time and you load it with hex files Flowcode creates.
But as I said earlier I don't believe it takes configuration settings into account.
This means if you enable the WDT and on real hardware you get watchdog resetting your hardware.
I don't believe the simulator will reset also.
Hello Martin,
Have you yet test the routine in actual hardware with servo?
Did it worked?
Also, ( excuse me if I am wrong but I am just a hobbyist!) in order to achieve the 0.1 ms interrupt interval shouldn't the interrupt frequency be set at 10 000 hz instead at 7812.500 hz as it appears in the interrupt macro properties in your routine?
Thank you,
Andreas Achilleos
Did it worked?
Thank you,
Andreas Achilleos
Hi Andreas ,
That's a good question.
Reason that's a good question is because I have added a comment in the timer0 routine within the flowchart how the 10KHz = 0.1 ms is produced, but left that out of tutorial: I have place several comments within the flowchart.
Yes I have fully tested on real hardware First using a servo. But I also scoped the waveform before connected up to the servo motor, just to be on the safe side.
When the pulse width duration displayed on the LCD agreed with the readings on the oscilloscope
I will add a bit more to the tutorialmedelec35 wrote: I am using a target device with an internal osc set at 8MHz.
Timer0 is set up to generate an interrupt every 0.1ms. so 20ms is 20/0.1 = 200 lots of 0.1 = Count value of 200. At this point portA0 goes from low to high.
So this 0.1ms will be the maximum resolution for the duration of the pulses generated every 20ms
actually I looked at that comment but my brain didn't quite get the meaning!!!
So, when you wrote : tmr0=+81; in the C code box it sets the timer0 to have an interrupt frequency of 10 000hz?
Is there a manual where you found out that or just advanced programming skills!
THank you Martin.
THank you Martin.
You are correct.achillis1 wrote: So, when you wrote : tmr0=+81; in the C code box it sets the timer0 to have an interrupt frequency of 10 000hz?
No I don't class myself as an advanced programmer.
I have read about setting tmr0 with a value from someware after reading a bit about timer interrupts,
But is was Sean which showed the fomat of tmr0=+any_byte_value
From here:
http://www.matrixmultimedia.com/mmforum ... f=5&t=6833
I have updated the tutorial, so it expains this point in more detail.
I use servo motors like the ones shown here.
http://www.amazon.co.uk/s/ref=nb_sb_nos ... vo&x=0&y=0
You may be able to get them cheaper by going somewhere like eBay.
Hi Andreas,
http://www.matrixmultimedia.com/product ... PHPSESSID=
Board is very useful for learning to control different motors.
Although you can buy them separately as ben has shown
I believe all servos could be driven in a similar manor.
When I get home I will post the model number of the servo that’s used.
Martin.
Sorry, I should have said it's from Matrix multimedia:medelec35 wrote:HPACT Motors board
6V DC supply for powering HPACT Motors board (or any suitable servomotor)
Martin.
- JohnCrow
I picked up a couple of Futaba servos from the local model shop, these are well made and come with a packet of different arms to swop on the axle.Think they were about £8 each. These work with both Martins program and the flowcode macros using the servo E-Block.
Here is a basic independent 4 channel servo controller again using 16F88 with 8MHz internal and no PWM or servo component.
There is nothing at all wrong with servo components. Since they allow fine trim adjustments, and the resolutions are probably greater. I'm looking in to the servo component of Flowcode next.
Any of the 4 channels can also be trimmed, by adjusting the formula (which is shown in the tutorial in the 1st post.)
The reason I have chose to use timer0 instead is so a smaller cheaper PIC Chip can be use which does not contain PWM component (which I believe two are required) for the servo component?
AN0 - AN3 control servos connected to B0 - B3 respectively.
I have kept all the clever stuff to a minimum (which is good as I'm not clever anyway
So you can simply see how to include more servos (or less) if required.
- Servo Controller 4 Channel V1 FC3 16F88.fcf
- (13.1 KiB) Downloaded 1500 times
I am trying to open your routine and I have an error!
I have attached.
Does anyone has a clue?
Thank you
Andreas Achilleos
I have attached.
Thank you
Andreas Achilleos
- (42.89 KiB) Downloaded 33928 times
I am trying to compile the first fcf file Servo Controller1 FC3 16F88.fcf and I get an error!
Funny thing, I tried that yesterday on my other PC and first ( due to the fact that I had messed a little bit with it!) I had the same error:''if your flowchart contais C code'', but after I downloaded it again and it was OK!
Now I keep getting the error and I have not altered the file.
Do you thing that PC configuration or folder location can cause these errors?
Martin, in your flowchart you state internal clock of the 16F88, so I must put the switch on the EB006 to the '' RC '' intead of '' XTAL '' ?
I didn't had the chance yesterday to test your routine when it was succesfully loaded into PIC due to trhe fact I do not have an ADC board!
Can your routine work with keypad instead?
Thank you.
Thank you.
- error.jpg (64.31 KiB) Viewed 69689 times
Hi Andreas,
The following warnings about ADC will be ignored etc, are there because a Flowchart created with Flowcode V3 is opened with Flowcode V4.
With V3 you need to sample ADC 1st then use another component to assign the value to a variable.
With V4 that's not the case. Sample part is not used, so it's simply ignored. Hence the warnings.
As for the Errors.
Common cause would be if target device is changed, and there is a component that had not reassigned.
Have you changed to a different target device?
If you would like to post the flowchart that's causing the issues, I can make sure it works on my system 1st.
As for the RC switch. On my EB006 I just moved the jumper that's next to the xtal from OSC to A6&A7 position
As for the Errors.
Hello Martin,
Thanks for the respond. The flowchart that is causing the erros is your own that I downloaded at the beginning of your post above!
As I told, on my other PC compiled just fine but in this one not, hence the questions I made if a PC configuration might be causing this.
I have not changed the target device.
Can I use that flowchart on 16F877A or 18F4550?
Thank you.
Thank you.
I was just wondering if you change target device.
But If you have not then that's odd?
Yes you can use any target device. I have successfully use a 18F4455 to drive servo, using flowchart posted.
Try this version that I have saved with with FC4
- Servo Controller 4 Channel V1 FC4 16F88.fcf
- (15.43 KiB) Downloaded 1428 times
This one compiles just fine!
Of course I do not have an ADC board so I can test it!
I will try to modify it and work with a keypad, do you think that would be easy?
I have one issue though and that might be happening because the servo board and or flowcode routine does not actually work as it should have. When I connect the power to my EB006 then the servo moves righwards, lets say. If I unplug the power and replug it then the servo moves the other way and this happens every time.
Do you get this when connecting the power?
Also where do you have the swithes on the EB006 on RC and slow?
Thank you.
Thank you.
With the jumper in this position, it does not matter what positions the two switches are, as I believe they are effectively disconnected from the microcontroller.medelec35 wrote:As for the RC switch. On my EB006 I just moved the jumper that's next to the xtal from OSC to A6&A7 position
No you don’t require Analogue on the target device.
The servo will work from byte variable 0 – 255
So this can be from a keypad ADC etc.
If using a keypad this would probably be the best way:
http://www.matrixmultimedia.com/mmforum ... 140#p18842
However the formula used will probably have to be changed to suit.
For example. Currently for servo to rotate to full CW byte = 0
for servo to rotate to full CCW byte = 255
With keypad, formula can be change so 1 to 20 can be used.
1 = full CW
20 = full CCW
2 – 19 = positions in between.
I think that I do not have such jumper!As for the RC switch. On my EB006 I just moved the jumper that's next to the xtal from OSC to A6&A7 position
Also, why change the formula for the keypad and have the 2-19 in between positions and not to have the 2-254?
Thank you!
