P16F1827 PORTB Interrupt (IOC)
fotios
Has thanked: 109 times
Been thanked: 117 times
Post by fotios »
Is there any upgrade for 16F1827?
a) In FC v4.5 PortB interrupt is not available.
b) In FC v5 the RC5 component is not working, i receive the known compiller error messages:
unknown identifier "RC5_1_MX_RC5_PWM_C2CON'
invalid operand "RC5_1_MX_RC5_PWM_C2CON'
Thank you
Best Regards FOTIS ANAGNOSTOU
Re: P16F1827 PORTB INTERRUPT (IOC)
What property settings are you using for the RC5 component in v5?
fotios
Post by fotios »
Here the error messages
Remote Control Handset MINI_v5.c(908:2): error: unknown identifier 'RC5_1_MX_RC5_PWM_C2CON'
Remote Control Handset MINI_v5.c(908:2): error: invalid operand 'RC5_1_MX_RC5_PWM_C2CON'
Here the RC5 properties window and my settings. It should be noted that RC5 compo is compiled and working correctly on FCv4.
Great thanks, I have managed to replicate the problem now.
Please can you try this updated component C file and see if this allows you to compile correctly.
FC5_PIC_RC5.c
(28.17 KiB) Downloaded 262 times
fotios
Re: P16F1827 PORTB Interrupt (IOC)
Post by fotios »
I finally managed to solve the compiling problem on FCv5. It is some odd, but... works!
The only thing that needed, is the activation of... whole the RC5 component. I mean both Receiver and Transmitter. Then the code is compilled on P16F1827 correctly and the project works perfectly on actual hardware. In the attached picture is shown the RC5 compo properties configuration. The only drawback is the loss of RB.0 and RB.1 ports, though no so much worry. For the given project - and for a feature upgrade to a bigger one - all RA.X ports remain available.
I will post the actual project in a new thread, i firstly have to draw the PCB.
Hello Fotios,
Ok thanks for letting me know, we are looking into the problem.
