PPP3
wjhos
Been thanked: 1 time
PPP3
Post by wjhos »
I managed to program 16f1825, using PPP3 ver. 3.14.18.33.However, that file got corrupted and i cant find it anywhere on this website.Pls helpme out. ver.3.11 cannot program 16f1825.
Re: PPP3
Here you go.
PPP v3.14.zip
(1.29 MiB) Downloaded 1071 times
wjhos
Re: PPP3
Post by wjhos »
Thanks, but it does not work. Starting PPP3 gives error ''Failed to get data for CONFIG8L'
Ignoring starts the program, but the config screen is cut, so no buttons can be used.
However, programming,reading etc. is possible, but no chip configuration.
Re: PPP3
The config window should be scalable by hovering your mouse near one of the edges of the window.
wjhos
Re: PPP3
Post by wjhos »
Resizable yes, but no accept or ok buttons appear.
Re: PPP3
Hmm that's odd, I have just tested it using v5 PIC and it's working fine. Could it be related to the Windows DPI setting or anything like that?
wjhos
Re: PPP3
Post by wjhos »
I do have v. 3.11 on cd, but that does not program 16f1825, but is working ok.
Is there a way to use the new PIC config files by this version. (copy/paste to the v. 3.11 directory does not work
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: PPP3
Post by DavidA »
When you say you cannot see the OK and cancel button could you provide a screenshot of the issue as this seems like a similar issue we have had with another user, where their windows DPI settings were set higher (this makes all the icons and windows bigger in Windows bigger)
If you are unsure of how to take a screenshot, please see this website:
http://take-a-screenshot.org/
wjhos
Re: PPP3
Post by wjhos »
I donot think it is adpi problem, but an installation problem. As i said, i had v3.14 installed till it crashed. The version i received from you runs after unzipping.
Anyway, i attach the screenshot.
Re: PPP3
Looks to be a DPI problem to me, you can see that the standard font is larger then it usually is. You can view your DPI settings here in Windows 7.
Start -> Control Panel -> Personalization -> Display
and then more options available by clicking
Set custom text size (DPI).
Both of mine are set to 100% default.
PPP does not need to be installed, it is simply a set of files that run.
Clicking off the config onto a blank part of the PPP config window may allow you to hit the enter key on your keyboard instead of clicking OK.
wjhos
Re: PPP3
Post by wjhos »
Problem solved, however i have to use my glasses to be able to read the small characters in normal windows screens.
Having said that still leaves me with the problem of the slow running pgm i posted on this forum. The program runs normally in an 16f877, but not in an 16f1825 (EB-006-00-7 board) Tried all kinds of clock settings, but no result.
Switching between different PIC's brought me to a nuissance in the list of PIC's in Flowcode. When building, select device, i get a list which to me makes no sense. There is no numeric/lexicografic order, all PIC's are in a random order, so difficult to decide if i have to scroll up or down or if i am in the vicinity of the wanted PIC. In PPP the order is more logical. Can something about that be done.
Thanks,
W.J. Hos
petesmart
Has thanked: 187 times
Been thanked: 140 times
Re: PPP3
Post by petesmart »
Hi Ben, Jonny,
I can also confirm that DPI causes all sorts of issues with display in all versions of FC V5, especially display of the MIAC image on the panel. I also the sawthe same config issue on beta dSPIC.
I first noticed this back in V4 versions, and I think that Jonny fixed or was working on a fix, can't remember now as it was a awhile ago.
I run my monitors at 125% as the resolution I'm running is very high, greater than 2k pixels...it's a 30" monitor so it's difficult to see the fonts when set to 100%.
All the best
Pete
sorry about that Chief!
mikky7
Re: PPP3
Post by mikky7 »
Programming,reading etc. is possible, but no chip configuration.
