RTC for MIAC(Part two)
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Hi Stuart
In this thread, we will start with basic MIAC program to make familiarization with MIAC. After couple of basic program, we will move to CAN test using MIAC and slave module without changing the slave circuitry. We will keep slave end of CAN bus as it is. Only MASTER end of CAN bus will be connected to MIAC (L) and (H) terminal and this time we will remove 120 ohm from Master end CAN bus and in MIAC we will close TA and TB terminal which will ultimately connect terminating resistor inside MIAC.
Have you tested any program in MIAC or it's still virgin? If so, I can post simple program to test MIAC.
Enamul
University of Nottingham
enamul4mm@gmail.com
acestu
Has thanked: 783 times
Been thanked: 223 times
Re: RTC for MIAC(Part two)
Post by acestu »
Hi Enamul,
I have powered up the MIAC and had a look at the test program.
thanks
Acestu
Enamul
Post by Enamul »
Hi Stuart,
I think the Keypad test is a nice program for MIAC to start with. This will help you to test LCD and Keypad components of MIAC which will be useful in our purpose later on..
3. Keypad Test.fcf
(10.5 KiB) Downloaded 555 times
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
I have installed the drivers for the MIAC and programmed your test program successfully
Acestu
Enamul
Post by Enamul »
That's nice. Here is another test code for ADC testing in MIAC..Here are 4 channels but you can use 1,2 or even 4.
2. Digital Volt Meter x 4.fcf
(12.96 KiB) Downloaded 511 times
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
I have programmed the MIAC with the Voltmeter code successfully but I don't know what I am supposed to do with it, I would imagine that it tells you the voltage at certain pins of the MIAC , I cannot see any marked I1, I2, I3 and I4.
Acestu
Enamul
Post by Enamul »
Hi Stuart
You should be able to see I1, I2, I3, I4 in MIAC as can be shown here..
(464.42 KiB) Downloaded 12260 times
You can see right to OR terminal I1, I2, I3 & I4 terminals. If you put variable voltage in those pin you should be able to see voltage in display.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Thanks Enamul
Do I use the 0v for ground / negative ? , I don't want to damage anything !
Acestu
Enamul
Post by Enamul »
0V is GND obviously but which -Ve you mean?
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Yes Sorry
thanks
Acestu
Enamul
Post by Enamul »
No problem at all.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
I have shorted out the TA & TB terminals on the miac and connected the can bus high and low then removed the resister from the master end....
thanks
Acestu
Enamul
Post by Enamul »
That's great. Here is the RTC code for MIAC and slave..
RTC_PIC18f4580_SLAVE.fcf
(48.54 KiB) Downloaded 504 times
RTC_MIAC.fcf
Please use the code in next post..this misses LCD start
(22.98 KiB) Downloaded 461 times
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul
I have programmed the MIAC and the Slave and when I power them both up the slave is showing time but the miac has a blank screen ?
Should the MIAC display show anything if the Canbus is not receiving anything ?
thanks
Acestu
Enamul
Post by Enamul »
Sorry there was a problem in MIAC code..it should be OK now.
RTC_MIAC.fcf
(23.12 KiB) Downloaded 475 times
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
I have reprogrammed the Miac but I still only get the "MIAC RTC Unit" text on the screen, I have a wired link in the TA and TB sockets and just 1 resister on the slave end of the Can Bus, but it is a 100 ohm, should I try and find a 120 ohm resister ?
thanks
Acestu
Enamul
Post by Enamul »
You can try but I don't think that is so critical. May be something wrong in the internal CAN and external CAN of MIAC. We have to go through some other tests may be.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Ok, that's great Enamul, only my luck hey ........
Acestu
acestu
Post by acestu »
Hi Enamul,
I have connected the slave board back up to the old master breadboard and the unit is working with both LCD modules showing the time and date, therefore the problem must be between the Canbus and the MIAC, I now have 120 ohm resistors on the Canbus as well, if you know of a test for the MIAC canbus I would be grateful.
thanks
Acestu
P.S. can both units be hooked up to the Canbus at the same time ?
acestu
Post by acestu »
I have been looking through the MIAC manual and it says that I require 4 wires as per my enclosed diagram, on my setup I have a link in the TA & TB connections, the Can bus Hi & Low in the L & H connections then I have a link in the M & +v connections, but I have nothing in the 0v connection, is this right ?
Acestu
Enamul
Post by Enamul »
I haven't told you anything about M& +V link. We don't need M pin at all. +V can be used or you can leave it depending on you. +V can be used as power supply for slave. MIAC datasheet is showing that..but you can use separate power supply for slave if you have or you can use +V. But you have to connect 0V pin of MIAC to GND of slave to have common ground. So for our case we can use 3 or 4 not necessary it must be 4.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
Can I just clarify what is meant by "So for our case we can use 3 or 4 not necessary it must be 4." please, if you mean it must be 4 wires, could you please show me how to connect to my breadboard
thanks
Acestu
Enamul
Post by Enamul »
Sorry for confusing you again. Can you please tell me where you running your slave PIC and RTC module from..I mean where it gets power from? If it's getting it's power from MIAC +V terminal in that case you will need 4 connections to slave. 2 are L& H, 1 is common GND (0V) and other is +V for slave +ve supply.
But if you are using separate power supply for Slave and RTC module you don't need +V connection of MIAC. You can simply ignore that. You need only L, H and 0V.
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
My Slave on the breadboard has its own +5v power supply that plugs into mains, and I am powering the MIAC from a mains PSU, so I think from what you are saying is
I only need to connect the Can Bus H & L , and connect the 0v on the MIAC to the neg rail on my breadboard
thanks
Acestu
Enamul
Post by Enamul »
Absolutely right.
Enamul
enamul4mm@gmail.com
