Whenever I program my PIC using either HP-488 or EB-006 programmer board on Flowcode V5.4, I just use the USB connector.
This means I have to enable "Low Voltage Program on the configure chip screen. When I click on Build>Project Options and click on "Configure chip" the screen looks incomplete and i can't find the buttons for cancel or options or whatever.
The screen I get is this
any amount of stretching the window will not work.
Please help...
Configure chip screen incomplete
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: Configure chip screen incomplete
I guess I have seen this issue before and David suggest to change screen resolution. The problem get sorted..You can try or you might have to wait till Monday.
mimiyum
- Been thanked: 1 time
Ok, I know now...it's not the screen resolution but the text size. My display text size was originally set to 125%. When I set it to normal the configure chip screen now looks normal.
I understand now that Flowcode may have been meant for younger people who have very good eyesight and don't mind small text on their screen
Thanks for the tip Enamul!
- Enamul
