Configure chip screen incomplete
mimiyum
Post by mimiyum »
Whenever I program my PIC using either HP-488 or EB-006 programmer board on Flowcode V5.4, I just use the USB connector.
This means I have to enable "Low Voltage Program on the configure chip screen. When I click on Build>Project Options and click on "Configure chip" the screen looks incomplete and i can't find the buttons for cancel or options or whatever.
The screen I get is this
(68.78 KiB) Downloaded 1857 times
any amount of stretching the window will not work.
Please help...
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: Configure chip screen incomplete
Post by Enamul »
I guess I have seen this issue before and David suggest to change screen resolution. The problem get sorted..You can try or you might have to wait till Monday.
Enamul
University of Nottingham
enamul4mm@gmail.com
mimiyum
Post by mimiyum »
Ok, I know now...it's not the screen resolution but the text size. My display text size was originally set to 125%. When I set it to normal the configure chip screen now looks normal.
I understand now that Flowcode may have been meant for younger people who have very good eyesight and don't mind small text on their screen :(
Thanks for the tip Enamul! :D
Enamul
Post by Enamul »
You are welcome. Thanks for letting us know.
Enamul
enamul4mm@gmail.com
