AVR Crash - Resolved
Please add any bug reports that require discussion here
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Post by JohnCrow »
When I try to save an AVR flowchart (Any device)
I get the following message
It seems to save the file, but if I try to open it I get the messge
Failed to open document
Attribute <Data> is not found
Arduinos will save though.
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: AVR Crash
Post by dazz »
Hi John
seems to save and open fine on my system (device) attached was one i did after your post to check (attached)
Dazz
avr save test.fcfx
(7.58 KiB) Downloaded 449 times
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: AVR Crash
Post by JonnyW »
Hi John.
Is there anything you add to the project, or can you create a completely blank project and get this message (I notice there are some component calls in the background).
Can you post a corrupted file - whereabouts in the file it fell down may give a clue as to what is happening (though its a long shot).
Jonny
JohnCrow
Re: AVR Crash
Post by JohnCrow »
Hi Jonny
I put one in my other post yesterday about not been able to compile other devices
At work at the moment. Will try a blank project tonight
JohnCrow
Re: AVR Crash
Post by JohnCrow »
Hi Jonny
Tried saving a blank flowchart, get the same results.
AVR_Crash.zip
(23.86 KiB) Downloaded 424 times
JonnyW
Re: AVR Crash
Post by JonnyW »
Excellent, thats caught it I think. There was a problem storing the config data - I think that will have fixed a couple of other strange config storage issues too.
Should be fixed in the next release.
Jonny
