Miac module
Nazaire VERRUE
Been thanked: 3 times
Miac module
Post by Nazaire VERRUE »
Dear,
The file in attachment work in the simulation and the file does not work in the Miac module.
What is it wrong?
Best regards
Nazaire Verrue
Oefening1a.fcfx
(6.36 KiB) Downloaded 377 times
Re: Miac module
Hi Nazaire,
I have tried your Flowchart on my Miac, and when I2 is high, output A goes high with LED lighting up.
So your flowchart is correctly working.
I have attached an alternative flowchart (not saying your flowchart is wrong since it's working),to show there is more then one way of controlling Miacs.
Also as a Miac test to see if your Miac is being programmed correctly , output D will be toggling every second as soon as power is connected
Oefening1b.fcfx
(9.48 KiB) Downloaded 392 times
Nazaire VERRUE
Re: Miac module
Hi Martin
The sw_toggle_mtl_pcb1 is connected with I1. I1 does not work but I2 work well.
What is it wrong?
Best regards
Nazaire
Re: Miac module
Hi Nazaire
Nazaire VERRUE wrote:The sw_toggle_mtl_pcb1 is connected with I1
It's connected to I2 not I1:
(21.54 KiB) Downloaded 4702 times
Since originally you did not state which input your connected to, I would not have known you wanted it to work with I1 instead of I2.
Just Change from I2 (RA1) to I1 (RA0).
You will need to take notice of functions that's not within brackets.
Nazaire VERRUE
Re: Miac module
Hi Martin
In the properties can i not sw_toggle_mtl_pcb1 connected with port A = 0 (RA0) there is alone port A = 1 or 2 or 3 or 4.
Wat is it wrong in tis properties of sw_toggle_mtl_pcb1?
Best regards
Nazaire
Re: Miac module
Not having problem with selecting I1 (A0):
(82.78 KiB) Downloaded 4694 times
(75.09 KiB) Downloaded 4694 times
If your having problems selecting I1, then are you running the latest version of V6 (6.0.2.0 (27.09.2013))
If not take a look at this:
http://www.matrixmultimedia.com/mmforum ... 54&t=12949
Perhaps you can post some screen shots to show what the issue is.
Attached is a Flowchart that is using input I1
Oefening1c.fcfx
(6.37 KiB) Downloaded 377 times
Nazaire VERRUE
Re: Miac module
Hi Martin
I am running now the latest version of V6 (6.0.2.0 (27.09.2013)).
Now it work correct.
Thanks Martin for the help.
Best regards
Nazaire
Re: Miac module
You're welcome Nazaire,
Thanks for letting us know.
