SSD1289 TFT SSD1963
STibor
Has thanked: 116 times
Been thanked: 113 times
SSD1289 TFT SSD1963
Post by STibor »
Hy,
Previously, I used the TFT components individually prepared Flowcode5.
http://www.matrixmultimedia.com/mmforum ... =50#p30753
How to import from Flowcode5 Flowcode4 re-written custom macros Flowcode6 program?
Cheap TFT displays SSD1289, SSD1963 at the new Flowcode6 not found in either.
Re: SSD1289 TFT SDD1963
I have found the custom code for the ssd1289 display. Will this also work with the ssd1963 device? I'll have a go at wrapping up the custom code into a component. Should be fairly simple to do.
STibor
Post by STibor »
I think the same is not the driver for the graphics controllers.
I recently bought the license Flowcode6 PIC, DSPIC and AVR for.
Try to use, but I do not know how you can use the old custom components.
Flowcode v6 has the ability to wrap your flowchart up into a component so hopefully there is no longer a need for the custom components. I'll see if I can do the coding and get the component out for testing. Do you have one of the SSD1289 devices to allow you to do some hardware testing?
STibor
Post by STibor »
Thank you!
Of course, I can test the display.
I'll put together a quick test circuit PIC18F26K20 controller.
I have Mega2560 Arduino + voltage drivers for the display adapter, but the program is difficult to control because the display port outputs are not routed to a port.
http://www.matrixmultimedia.com/mmforum ... 497#p49610
http://www.digibay.in/index.php?route=p ... uct_id=146
Right here is a component for the SSD1289 based on the custom code file.
gLCD_SSD1289.fcpx
(53.83 KiB) Downloaded 755 times
Let me know how you get on with it, if it's ok then I'll add it to the next release.
STibor
Re: SSD1289 TFT SSD1963
Post by STibor »
Hi Ben!
Thank you very much!
I tried it, it works!
A single mistake that the blue and red has been replaced.
Furthermore, the problem was 18F26K20.fcdx file.
"<pin name='RC3/SCK/SCL' />" changed "<pin name='RC3/SCK/SCL' port='2' bit='3' />" so RC3 IO port.
How to made this is the component file?
Ok I have switched the Blue and the Red and hopefully this should now work ok. Could not find a good colour map for 16-bit mode in the IC datasheet so there could potentially be more issues lurking. (Edit found the 16-bit colour map now and the original setting looks more correct? Let me know how you get on with this component.)
gLCD_SSD1289.fcpx
(53.82 KiB) Downloaded 633 times
Let me know if you find anything else.
Also thanks for the spot on the FCD, I'll fix it here so it is fixed for the next patch.
Would it be useful for you to see the source for the component to maybe be able to create new components for other display controllers?
STibor
Post by STibor »
Was very good.
I have found a mistake.
The program has a "C" program:
osccon = 0x70;
st_bit(osctune, PLLEN);
When I left the project, and there is not I open the code "C".
Just a blank "C code" flowchart.
Making a demo program and video recorders, the square is drawn over a lack of size heel.
ssd1289_demo_II.fcfx
(9.76 KiB) Downloaded 561 times
C code.jpg (29.44 KiB) Viewed 17715 times
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
Hello. This will be fixed in the upcoming patch, apologies for this.
Jonny
STibor
Post by STibor »
I tried the code PIC24EP128MC202 controller, unfortunately, does not work.
ssd1289_III_5_PIC24EP128MC202.fcfx
(28.5 KiB) Downloaded 520 times
probe_glcd_24bit.txt
(4.93 KiB) Downloaded 524 times
STibor
Post by STibor »
It works!
Clock was a problem.
8 bit http://youtu.be/pb3XcMVckA0
16 bit http://youtu.be/6qldGJs8wjY
Glad you got it all working and those vids look great. Thanks for letting us know.
STibor
Post by STibor »
Thanks for your help!
If I'm not annoying, would later write of my experiences with my problems GLCD component.
No problem, just doing my job :D
Yes we would love to hear any problems you encountered along the way and your thoughts/experiences. This kind of information is crucial for moving forward successfully with our support and documentation.
Mikat
Has thanked: 7 times
Been thanked: 36 times
Post by Mikat »
Hi.
The code of the SSD component is probably originally written by me. The code don't work at the 1963 driver, or at least I think so, it has never written at 1963 driver..
BUT when I looked the the 1963 datasheet (for long time ago) it looks that the differences could be only at the init routine, so rewritten the init at the 1963 driver, the code could work.. But I don't remember now has the code some limitations at the 320x240 resolution...
BTW, is it the video, or is the code that slow? Whats the MIPS of the chip at 16bit mode?
Mika
STibor
Post by STibor »
Mikat wrote: Whats the MIPS of the chip at 16bit mode? Mika
The old test video controller running 70MIPS speed.
Here is the new video test.
Clock 200MHz 200MIPS little overclocking.
http://www.youtube.com/watch?v=Df_FUASP ... Ik7Km-R28Q
trey3499
Post by trey3499 »
Hello!
Is it possible to make SSD1963 Custom under AVR Flowcode5?
In advance many thanks.
