A simple keyreader, that doesnt read
E*2Engineer
Has thanked: 12 times
Been thanked: 6 times
Post by E*2Engineer »
Hello all,
I am doing this keyboard reading example in "intro to micros".
My program is running as a simulation, but not on my QL200 development board.
I have been able to run all examples in the course so far, with a few modifications to the coding of ports.
This one however is not running on the board, so attached is the QL200 schematic, and my .FCF
I can see (via the data line LED'S) the micro is managing to scan the keys to a point, but then C0,C1, & C2 stop toggling, and nothing ever displays on the LCD at all.
I have used Port C for the keyboard, as that is how the DEV board is wired.
Any help wold be appreciated.
Thank you,
Jeff
Addendum:
I am using a PIC16F877A PROCESSOR!
LCD CORRECT CONFIGURATION.jpg (34.05 KiB) Viewed 5475 times
QL200_SCH.pdf
I have S4 for the extra column of keys turned off (disconnected), so it would be the same as the E-Blocks version of the example, under Strings and Memory/ Exploring the keys, in the "intro to Micros" example.
(95.17 KiB) Downloaded 421 times
KEPAD SENSE AND READ 1 19 14 1245.fcf
Very simple, same as in intro to micros course.
(8 KiB) Downloaded 414 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: A simple keyreader, that doesnt read
Post by kersing »
Please do not use all capital subjects.
― C.S. Lewis
Kenrix2
Flowcode v5 User
Has thanked: 72 times
Been thanked: 177 times
Re: A SIMPLE KEYREADER, THAT DOESNT READ
Post by Kenrix2 »
Try turning off the watch dog timer and low voltage programming in chip configure and set the clock speed in project options to whatever the actual speed is and see how it runs.
E*2Engineer
I found that I was seeing no display without putting in a delay after the print command, as the display is so slow to react.
Also, i found the port lines were not being pulled up hard enough, despite the on board 10K Ohm pullup SIP for port C.
This was giving me erratic results after I put the print delay in. I put another set of pullup resistors in parallel, and the numbers became consistent.
So thanks for your suggestions!
