Program Wont Compile to HEX
JDR04
Has thanked: 111 times
Been thanked: 13 times
Post by JDR04 »
Hello everybody, could somebody please tell me why I cant convert to hex. I've attached the screen grab of my settings and the eerror.
Do these settings change from program to program? I tried using the same settingsd the last time I programmed a 16F690 PIC but must have made an error along the line.
Have also attached the program. Thanks so much for your help - John
IST ERROR.doc
(314.99 KiB) Downloaded 372 times
INFARED CAMERA TRIGGER 1.fcf
(17.5 KiB) Downloaded 368 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Program Wont Compile to HEX
Post by kersing »
If you read the errors carefully you will notice the error is generated by the linker, not the programmer. I suspect the spaces in your filename are the cause of the error. Try saving the Flowcode file without spaces in the name.
― C.S. Lewis
JDR04
Post by JDR04 »
Thanks kersing, I tried that but the error was still the same.
In the hope I have made things easier for you guys, I have attached 2 files with screen grabs of my settings. Maybe I screwed something up here.
Appreciate your help,thanks again-John
(113.79 KiB) Downloaded 1792 times
(71.77 KiB) Downloaded 1792 times
electron67
Has thanked: 106 times
Been thanked: 48 times
Post by electron67 »
tried with: watch dog: off
brown out detect : BOD disabilited and SBOREN disabilited
internal external switch over mode : disabilited
montitor clock fail- safe : disabilited
Electron67
JDR04
Post by JDR04 »
Thanks electron67, tried all that but the error report is still the same.
I have done a screen grab of it as this will be better than me trying to explain it.
Any help out there will be appreciated. Thanks a lot........John
(81.12 KiB) Downloaded 1776 times
Crenwick
Has thanked: 7 times
Been thanked: 21 times
Post by Crenwick »
Have a check in Compiler options/Compiler if the parameters are
For location:
C:\Program Files (x86)\Flowcode\v5\Tools\boostc\boostc_pic18_flowcode.exe
For parameters :
-v -t PIC%p "%f.c"
I think you set the "Programmer" params of PICkit in the Compilers params :wink:
Bernard
Flowcode 6 / EB006-V9
JDR04
Post by JDR04 »
Thanks for the reply crenwick, but it seems to have got worse as now it wont compile to c either!!!!
Thanks anyway......John
(41.68 KiB) Downloaded 1772 times
kersing
Post by kersing »
Hi John,
It looks like you are missing spaces in both the location and parameters. Also, are you using 64 bit windows? If not remove " (x86)" from the location.
Jac
― C.S. Lewis
Crenwick
Post by Crenwick »
kersing wrote:Hi John,
Jac
+1 with Jac :wink:
Bernard
JDR04
Post by JDR04 »
Tried that did not work. I have attached more screen grabs, hopefully somebody will see me right on this.
Thanks to all for their help so far...............John
(99.76 KiB) Downloaded 1761 times
kersing
Post by kersing »
Now your location is missing a few characters.
Please cut-and-paste the two strings listed below:
C:\Program Files\Flowcode\v5\Tools\boostc\boostc_pic18_flowcode.exe
Parameters:
-v -t PIC%p "%f.c"
Alternatively, select <default> from the option list to reset to (hopefully) known good values. Try to build to HEX (Arrow pointing to white box with 10001) before changing the programmer settings.
― C.S. Lewis
JDR04
Post by JDR04 »
Thanks a lot kersing, really appreciate your effort to help me. Its compiled to C and to HEX with no errors.
I'll burn the chip later tonight and see what happens.
Really appreciate your guys time.
Many Thanks..........John
