Dear Sir,
I spend lot's of time of Flowcode V6 + AVR atmega328 + w5100 Webserver.
I found :
1. The html page has been limit in 360 characters
2. The %veriables% have not in stead by ver. You got " Temperature = %BOO1% " from the page.
Please see the attach files ...
I can work with 360 characters limit by small page information. But can't show any %ver% makes me crazy.. Need Help..
Problem with AVR+Webserver
damstech8888
- Has thanked: 1 time
- WEBV6T1.fcfx
- AVR atmega328 + w5100 Webserver
- (7.11 KiB) Downloaded 235 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Problem with AVR+Webserver
The V6 Webserver In and Out Values are implemented differently to V5.
The Out values are set using the macro SetOutValue(index, string)
So in your html you would need Temperature = %1
where %1 will be replaced with the text set for index = 1
If you have an integer value that changes, e.g. BOO1, then convert it to a sting and pass it to SetOutValue
This change was made for V6 to avoid the byte integer limitation
Leigh
BOO1 = BOO1 + 1
StringBOO1 = STRING BOO1
SetOutValue(1, StringBOO1)
Leigh
damstech8888
Thank you, Leigh. It works!
Where can I found the real V6 examples for components, I can only found examples for V5. Even it says for V6.
And where can I get the training documents for V6, to help self learning.
B.R.
Peter
B.R.
Peter
