Problem with AVR+Webserver
damstech8888
Has thanked: 1 time
Post by damstech8888 »
Dear Sir,
I spend lot's of time of Flowcode V6 + AVR atmega328 + w5100 Webserver.
I found :
1. The html page has been limit in 360 characters
2. The %veriables% have not in stead by ver. You got " Temperature = %BOO1% " from the page.
Please see the attach files ...
I can work with 360 characters limit by small page information. But can't show any %ver% makes me crazy.. Need Help..
WEBV6T1.fcfx
(7.11 KiB) Downloaded 235 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: Problem with AVR+Webserver
Post by LeighM »
The V6 Webserver In and Out Values are implemented differently to V5.
The Out values are set using the macro SetOutValue(index, string)
So in your html you would need Temperature = %1
where %1 will be replaced with the text set for index = 1
If you have an integer value that changes, e.g. BOO1, then convert it to a sting and pass it to SetOutValue
BOO1 = BOO1 + 1
StringBOO1 = STRING BOO1
SetOutValue(1, StringBOO1)
This change was made for V6 to avoid the byte integer limitation
Leigh
damstech8888
Has thanked: 1 time
Thank you, Leigh. It works!
Where can I found the real V6 examples for components, I can only found examples for V5. Even it says for V6.
And where can I get the training documents for V6, to help self learning.
B.R.
Peter
