I have managed to transfer simple blinking program to Arduino Duemilenove board (ATmega 328p). Simulation runs perfectly and LED is connected to pin 13 (Port D 7) but nothing happens.
Here is what I get:
Target folder: C:\DOCUME~1\Djordje\Desktop
Source name: C:\Documents and Settings\Djordje\Desktop\Blink31 flowcode v6.fcfx
Title:
Description:
Device: AVR.ATMEGA.ATMEGA328P
Generated by: Flowcode v6.0.9.0
Date: Monday, July 21, 2014 14:26:18
Users: 0
Registered to: 18767228
Licence key: 1XH0MZ
NOT FOR COMMERCIAL USE
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files\Flowcode 6\compilers\avr\batchfiles\avra.bat atmega328p "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.elf" "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.c" "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.lst"
Launching compiler...
C:\DOCUME~1\Djordje\Desktop>"C:\PROGRA~1\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega328p -Os -funsigned-char -o "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.elf" "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.c" -lm
C:\DOCUME~1\Djordje\Desktop>"C:\PROGRA~1\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-objdump.exe" -S "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.elf" 1>"C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.lst"
C:\DOCUME~1\Djordje\Desktop>"C:\PROGRA~1\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-size.exe" -B -d "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.elf"
text data bss dec hex filename
816 0 22 838 346 C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.elf
Compilation successful!
Completed compilation, return = 0
C:\Program Files\Flowcode 6\compilers\avr\batchfiles\avrb.bat "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.elf" "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.hex" "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.cof"
C:\DOCUME~1\Djordje\Desktop>"C:\PROGRA~1\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-objcopy" -O ihex -R .eeprom "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.elf" "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.hex"
HEX file creation successful!
C:\DOCUME~1\Djordje\Desktop>"C:\PROGRA~1\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-objcopy" -O coff-avr -R .eeprom "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.elf" "C:\DOCUME~1\Djordje\Desktop\Blink31 flowcode v6.cof"
COFF file creation successful!
Launching the programmer...
C:\Program Files\Flowcode 6\compilers\avr\batchfiles\avrc_arduinoA.bat m328p stk500 com3 57600 "Blink31 flowcode v6.hex"
C:\DOCUME~1\Djordje\Desktop>"C:\PROGRA~1\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avrdude.exe" -p m328p -P com3 -b 57600 -c stk500 -U flash:w:"Blink31 flowcode v6.hex"
avrdude.exe: successfully opened stk500v1 device -- please use -c stk500v1
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude.exe: Device signature = 0x1e950f
avrdude.exe: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude.exe: erasing chip
avrdude.exe: reading input file "Blink31 flowcode v6.hex"
avrdude.exe: input file Blink31 flowcode v6.hex auto detected as Intel Hex
avrdude.exe: writing flash (816 bytes):
Writing | ################################################## | 100% 0.44s
avrdude.exe: 816 bytes of flash written
avrdude.exe: verifying flash memory against Blink31 flowcode v6.hex:
avrdude.exe: load data flash data from input file Blink31 flowcode v6.hex:
avrdude.exe: input file Blink31 flowcode v6.hex contains 816 bytes
avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 0.36s
avrdude.exe: verifying ...
avrdude.exe: 816 bytes of flash verified
avrdude.exe done. Thank you.
Programming successful!
FINISHED
>>>>NOTE <<<
When programmed with Arduino software works fine (Blinking prg )
Please help !
With best regards,
Djordje
P.S.
I did not manage to attach screenshots.
Arduino duemilanve problem
Re: Arduino duemilanve problem
Please can you attach your Flowcode program .fcfx file and I will have a look and see if I can spot what's causing the problem.
Thank you so much. Here are also screenshots of setting files.
With best regards,
Djordje
With best regards,
Djordje
- Blink3 1.fcfx
- File
- (4.13 KiB) Downloaded 632 times
- Settings
- Arduino Flowcode image 3.JPG (69.3 KiB) Viewed 18716 times
- Settings
- Arduino Flowcode image 2.JPG (66.73 KiB) Viewed 18716 times
Your output is on pin7 you need d13 which is pin(on chip) 19 or pb5 change it on the led properies
Dazz
Dazz
Hi Duzz,
THANK YOU so much. I have mistaken Pin 13 with Digital 13 and overlooked it million times. Thank you. You were mos kind. All the best to you.
Best regards,
Djordje
Best regards,
Djordje
Glad it's working, dont worry about the wrong pins we have all done it
