Going Crazy on a Direction tree
JLeith
Has thanked: 146 times
Been thanked: 26 times
Post by JLeith »
Hello All,
It has been a year since I did my big project and now I was trying to build another and I have no idea why this flow won't work.
I have looked over it so many times my eyes are getting crossed eye.
I know it has to be something simple I have missed.
All I want to do is press the button and the led should light and the LCD should display.
I can't get the button to trigger.
I have added the very simple Flowcode if someone can shed light on what I'm missing.
Thank you
John
Segment control Flowcode.fcf
(17.29 KiB) Downloaded 300 times
Re: Going Crazy on a Direction tree
Hi John,
The switch function name can be misleading.
It is not an input for a switch.
Its function is to take a different branch depending on the result of a variable.
Take a look here:
http://www.flowcode.co.uk/mmforums/viewt ... 57&#p59557
http://www.flowcode.co.uk/wiki/index.php ... Properties
You will still need to use an input icon, or a component icon that relates to the switch on the panel called Switch(0) to read the switch.
Segment control Flowcode V2b.fcf
(15.71 KiB) Downloaded 290 times
Segment control Flowcode V2a.fcf
(15.76 KiB) Downloaded 278 times
JLeith
Post by JLeith »
Thank you for the info I have printed off the Flowchart link and add it to my knowledge book.
All the best and I will review my mystery and add a little more routes.
All the best
