Hello All,
It has been a year since I did my big project and now I was trying to build another and I have no idea why this flow won't work.
I have looked over it so many times my eyes are getting crossed eye.
I know it has to be something simple I have missed.
All I want to do is press the button and the led should light and the LCD should display.
I can't get the button to trigger.
I have added the very simple Flowcode if someone can shed light on what I'm missing.
Thank you
John
Going Crazy on a Direction tree
- JLeith
- Has thanked: 146 times
- Been thanked: 26 times
- Segment control Flowcode.fcf
- (17.29 KiB) Downloaded 299 times
Re: Going Crazy on a Direction tree
Hi John,
The switch function name can be misleading.
It is not an input for a switch.
Its function is to take a different branch depending on the result of a variable.
Take a look here:
http://www.flowcode.co.uk/mmforums/viewt ... 57&#p59557
http://www.flowcode.co.uk/wiki/index.php ... Properties
You will still need to use an input icon, or a component icon that relates to the switch on the panel called Switch(0) to read the switch.
Take a look here:
- Segment control Flowcode V2b.fcf
- (15.71 KiB) Downloaded 290 times
- Segment control Flowcode V2a.fcf
- (15.76 KiB) Downloaded 278 times
- JLeith
Hi Martin,
Thank you for the info I have printed off the Flowchart link and add it to my knowledge book.
All the best and I will review my mystery and add a little more routes.
All the best
All the best
