Override ICD pins causes failure to communicate
A forums to allow bugs and problems with Flowcode v6 to be reported and resolved.
NickDA
Has thanked: 1 time
Post by NickDA »
I've got a problem using the ICD/Ghost. ICD works when using the default pins (RB6/RB7) but crashes with anything else (see error.jpg).
[attachment=1]error.jpg[/attachment]
I'm only running a simple 'flash an LED' program on a PIC16F877A (can't get much simpler) in Flowcode v6.1.0.0 (08.10.14) and a Ver 9 EB-006. Setup shown in setup.bmp.
[attachment=0]setup.jpg[/attachment]
I notice that in the Help Wiki it says "you can in theory use any I/O pin for the ICD" - is this still a theory or has anyone tried it in practice? It's obviously a workroundable problem but I find PORTB rather useful and I'd prefer to use PORTE and not "lose" two pins from PORTB.
Best regards,
Nick
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Override ICD pins causes failure to communicate
Post by kersing »
Nick,
The software allows changing to other pins, however the EB006 hardware is wired to use the PORTB pins.
Best regards,
Jac
― C.S. Lewis
