I've got a problem using the ICD/Ghost. ICD works when using the default pins (RB6/RB7) but crashes with anything else (see error.jpg).
[attachment=1]error.jpg[/attachment]
I'm only running a simple 'flash an LED' program on a PIC16F877A (can't get much simpler) in Flowcode v6.1.0.0 (08.10.14) and a Ver 9 EB-006. Setup shown in setup.bmp.
[attachment=0]setup.jpg[/attachment]
I notice that in the Help Wiki it says "you can in theory use any I/O pin for the ICD" - is this still a theory or has anyone tried it in practice? It's obviously a workroundable problem but I find PORTB rather useful and I'd prefer to use PORTE and not "lose" two pins from PORTB.
Best regards,
Nick
Override ICD pins causes failure to communicate
- setup.jpg (53.15 KiB) Viewed 2806 times
- error.jpg (26.22 KiB) Viewed 2806 times
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: Override ICD pins causes failure to communicate
Nick,
The software allows changing to other pins, however the EB006 hardware is wired to use the PORTB pins.
Best regards,
Jac
Best regards,
Jac
― C.S. Lewis
― C.S. Lewis
