WiFi Communication with ESP8266
hyperion007
Has thanked: 49 times
Been thanked: 101 times
Re: WiFi Communication with ESP8266
Post by hyperion007 »
Ben, could I trouble you for a change to the component again? :roll:
Add 3 more input variables with configurable buffer length.
This should now have the additional 3 incoming buffers.
WLAN_ESP8266.fcpx
(22.81 KiB) Downloaded 789 times
ajneal4uk
Has thanked: 1 time
Been thanked: 1 time
Post by ajneal4uk »
Hi;
So I purchased a ESP8266 and thought id give it a try.
I'm testing with one of the programs in this tread but I am unable to compile to chip without errors.
I searched other threads and found someone else with the same problem. I tried the component our valued contributor kersing posted and was able to compile without issue.
I'm using flowcode for dspic.
The prototype "void FCD_08181_WLAN_ESP8266__ServerSendHTML(const MX_CHAR *FCL_DATA, MX_UINT16 FCLsz_DATA);" is defined 4 times.
If anyone can help I would be most grateful.
Andy
void FCD_08181_WLAN_ESP8266__Send_Embedded_HTML_Page1() {
FCD_08181_WLAN_ESP8266__ServerSendHTML("<html>\r\n", 10);
FCD_08181_WLAN_ESP8266__ServerSendHTML("Main Index Page\r\n", 19);
FCD_08181_WLAN_ESP8266__ServerSendHTML("</html>", 8);
void FCD_08181_WLAN_ESP8266__Send_Embedded_HTML_Page2() {
FCD_08181_WLAN_ESP8266__ServerSendHTML("Page 2\r\n", 10);
void FCD_08181_WLAN_ESP8266__Send_Embedded_HTML_Page3() {
FCD_08181_WLAN_ESP8266__ServerSendHTML("Page 3\r\n", 10);
void FCD_08181_WLAN_ESP8266__Send_Embedded_HTML_Page4() {
FCD_08181_WLAN_ESP8266__ServerSendHTML("Page 4\r\n", 10);
cobra1
Has thanked: 3 times
Been thanked: 3 times
Post by cobra1 »
This little module looks quite interesting. I was wondering if i might be able to get a pointer.
I would like to use the modules as slave devices connected to a router which is connected to the internet. The router will be setup for port forwarding allowing me to communicate with the slave devices connected to the router from a remote location.
The part i need a little guidance with it actually communicating with the slaves. Do i have to have a webserver running on each slave or can i simply send a string of data and receive string data back? This would be my preffered method of communication.
If it possible could anyone give and information on how to proceed.
bicli
Post by bicli »
cobra1 wrote:This little module looks quite interesting. I was wondering if i might be able to get a pointer.
Why not use MQTT?
bicli
Post by bicli »
Hello guys, I am using this sucker as an MQTT client that sends sensor information to the broker and in order to save power consumption, I tried using system_deep_sleep call but then realized that XPD_DCDC pin needs to be connected to EXT_RSTB. My problem is, I have ESP-01. Is there any possibility to make it happen?
Any help would be great.
Thanks,
Bekir
ajneal4uk
Has thanked: 1 time
Post by ajneal4uk »
Hi all;
I as wondering if anyone else was having issues when compiling the flowcode to chip?
Andy
Hello Andy,
Please can you post the program that is generating compilation errors.
ajneal4uk
Has thanked: 1 time
Post by ajneal4uk »
Hi Ben;
All I've done is setup a new project dropped the component on the work area and initialised the it.
I've also looked at the source code that you provided but when I export as a component the result is the same.
"void FCD_08181_WLAN_ESP8266__ServerSendHTML(const MX_CHAR *FCL_DATA, MX_UINT16 FCLsz_DATA);" is duplicated and the compiler rejects the code.
Andy
Flowcode1.fcfx
(5.5 KiB) Downloaded 698 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
Hi Andy,
The attached component should fix the function prototype error.
Leigh
WLAN_ESP8266.fcpx
(22.83 KiB) Downloaded 583 times
gulik154
Post by gulik154 »
Benj wrote:Hello
Yes this is coming soon. I've got a module working and replying correctly and made progress on the Flowcode component this afternoon. So far everything is working well and I hope to finish the component tomorrow.
hi Benj I still make use of Flowcode V4 for PICmicros
question can also use the code
greeting JM
cruzxia
Been thanked: 8 times
Post by cruzxia »
I have been setting up an ESP8266.
I have the serial connected and working.
The problem I am having is the GETINVALUE macro failes to provide me the incoming string data.
if I use GETBYTEWITHTIMEOUT and print as Ascii I can see the data on the LDC screen
Using the GETVALUE micro, I am saving it as a string, and then printing the string on the LCD.
I have tried all index 0-2, but there is still no data. (The LCD stays blank)
This is the data I receive on my PIC when I send to the module from my laptop.
+IPD,1,289:GET /?but=2 HTTP/1.1
Host: 192.168.4.1
Connection: keep-alive
Accept: */*
Origin: null
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2272.101 Safari/537.36
Accept-Encoding: gzip, deflate, sdch
Accept-Language: en-US,en;q=0.8
Any help will be appreciated
cruzxia
I think you need to change this line.
to this.
+IPD,1,289:GET /?0=2 HTTP/1.1
then use index value 0 to collect the value.
You can probably use the RS232 component in Flowcode v4 to talk with the module. If you want the component then upgrading to v6 would give you this functionality.
cruzxia
Post by cruzxia »
Thanks for the info on the indexing, it worked once I changed the value.
It does seem a bit erratic when it checks the data. I can see the data coming in (when the led on the ESP8266 goes blue), It sum times displays immediately, and other times it takes a while before it will display or just does not display at all.
In the check for page requests, I am checking the return value for a non zero. If it is non zero I Get the in value, to receive the data.
If I don't test for the non zero value then it just keeps returning the same value, so it is reading the buffer again.
Do I need to clear the buffer manually after each read?
Is the buffer big enough to store all the incoming string data?
This is the incoming data from the ESP8266 (I sent the data "hello")
+IPD,2,290:GET /?0=hello HTTP/1.1
Host: 192.168.4.1
Accept: */*
Origin: null
cruzxia
The "In" buffers are cleared when a valid page request is received.
This could be moved so that it happens by default when you call the check for requests function. I've done this mod and the new component is below.
WLAN_ESP8266.fcpx
(22.83 KiB) Downloaded 553 times
The size of each buffer is assigned in the ESP8266 component properties, the default is 20 bytes.
ahmedkhalid
Has thanked: 4 times
Post by ahmedkhalid »
Hello everyone,
CIPSTART="TCP","www.flowcode.co.uk",80
gives :
OK
Linked
now how to send a GET request to this site as mentioned by benj
I am using RealTerm..
Firmware version is:
00170901
Hello All,
I know this topic has gone quiet but I have been working with this component again today for a new development and found a bug which had the potential to brake TCP servers so thought I would share the fix.
WLAN_ESP8266.fcpx
(23.01 KiB) Downloaded 528 times
Simply place the file into your "Flowcode 6/Components" folder.
I have also been through and tested out core examples and put them on the Wiki. They are now all working well for me so it made sense to have them available.
http://www.flowcode.co.uk/wiki/index.php ... 6ada46f7bf
I used an EB091 for the examples but an EB006 or Arduino etc. should work just as well.
Any problems let me know.
Found and fixed another bug linked with the Outbound string substitutions. The out variable length was being truncated to 20 bytes due to a fixed length intermediate variable. This variable has now been removed and we use the value directly to save a bit of RAM usage. Note that outbound strings lengths will still be limited to a 8-bit value 0-255 as the Length$() function currently returns an 8-bit value. I'm tempted to make this into a 16-bit value but I will investigate what the knock on effect would be.
WLAN_ESP8266.fcpx
(22.96 KiB) Downloaded 500 times
roussetp
Post by roussetp »
I try to create a Web server with the ESP8266 component. I loaded your component
WLAN_ESP8266.fcpx and created FLOWCODE attached file . WIFI access point works and I can
Connect to. But when I run a web browser with WIFI address, he replied unauthorized access !
I do not know what to do after many hours of testing. Can you help me please?
Thank you in advance.
cordially
Essais WIFI V6.fcfx
test file
(24.61 KiB) Downloaded 498 times
roussetp
Post by roussetp »
I found the solution to my problem. I had not entered the correct IP address.
electron67
Has thanked: 106 times
Been thanked: 48 times
Post by electron67 »
some days ago download WLAN_ESP8622 examples of help component and also install the component in flowcode6, I'm testing
the flowchart of the examples but when I go to copilar ends in failure -2.
There is a component failure or no longer works in flowcode6? Also note that the examples are not published in the Help page
of the component.
Enrique
electron67
change the PIC16F887 by the 18F4620 and if he could compile
Enrique
