Problems with new EB006V9 with Flowcode V4 on Windows XP Pro
Joel_Le_Gac
- Been thanked: 1 time
I just begin to use EB006V9 boards today, but I have problems to install drivers correctly.
I work on Flowcode V4 under Windows XP Professionnal.
I connect my EDB006V9 board to USB port.
But drivers or mLoader seam to be not recognised.
What can I do ?
- Can I use PPP as on Flowcode V4 ?
- I have also downloaded mLoader on the website of Matrixmultimedia, but this version does not seem compatible with Flowcode V4 : the file .hex generated with Flowcode V4 is well transmitted, but that does not go on the EB006V9 board.
Can you help me, please, by transmitting me correct mLoader or drivers ?
Thanks very much.
What can I do ?
Thanks very much.
Joel_Le_Gac
Re: Problems with new EB006V9 with Flowcode V4 on Windows XP
Thanks, Martin, for your reponse.
Excuse-me if I don't speek english very well. I'm french !!!
Yes, I have downloaded drivers from your website :
EB006 (v9) USB Driver and mLoader Programming Software
I have done all it's describe in joined file.
mLoader seem to work correctly : when I connect EB006V9 to a USB port, board is detected.
When I click on Autodetect button, mLoader recognised the microcontroller 16F877A I have monted on the board.
When I select a .hex file generated on Flowcode V4, and when I click on Send button, file is transfered in microcontroller, the LED Program flickers on board... But after the transfer, the program does not run...
I wonder whether the files that I have downloaded are compatible with Flowcode V4.
Thanks for your help.
Joel
Joel
- Using EB006v9 with Flowcode v4 and v5.pdf
- (161.79 KiB) Downloaded 1090 times
Hi Joel,
You're welcome.
Sounds to me like programmer is working as intended and issue is configuration settings within flowcode (Chip, configure).
Take a look at this
For your interest you get configure Flowcode V4 to compile directly to chip, rather than loading hex file.
Take a look here.
If you are still struggling then if you post flowchart then I will see if I can spot the issue.
So I can move this thread to the correct section, What version of flowcode V4 are you running?
Professional, student etc.
You're welcome.
I don't work for Matrix, I just help out when I can.Joel_Le_Gac wrote: Yes, I have downloaded drivers from your website
Take a look at this
Take a look here.
Joel_Le_Gac
Thanks, Martin,
we have Flowcode V4 for PICmicro : view joined file
It's a Flowcode Educational Version for 50 postes.
When we buy it, it was Flowcode V4.3
For testing Flowcode with mLoader, and viewing configuration settings, I can do it tomorrow, at my school.
I have done all is detailed in http://www.flowcode.co.uk/faq/index.php? ... artlang=en
I have load mLoader v.3.2.2.6 and copy the files in a mLoaderPIC folder :
Location: C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\Tools\mLoaderPIC\mLoader.exe
Parameters: -chip %p "%f.hex"
I can give you tomorrow screen printings.
Goodbye, and thanks very much for all your help.
Joel
Joel
- mLoader_for_FC4and5.jpg (38.29 KiB) Viewed 44634 times
- FlowcodeV4.jpg (69.05 KiB) Viewed 44634 times
Joel_Le_Gac
Hi, Martin,
I have seen I 've done an error in parameting compiler options in Flowcode.
The top two fields set the programmer location, it is these you want to edit. Leave the bottom two fields as is to allow the configuration functionality to continue to work.
Change the top two fields to look like this :
Flowcode v4
I've done this for the top two fiels, but also for the bottom two fields.
Perhaps is this because of that that does not go ?
I'll do modifications tomorrow, and I will transmit you my observations.
Goodbye, and thanks very much.
Joel
Flowcode v4
Joel
Yes you will need to leave those for PPP as that is used to set the configuration settings.Joel_Le_Gac wrote:Leave the bottom two fields as is to allow the configuration functionality to continue to work.
My settings for 'Use external program to set configuration options' are:
Location:C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\Tools\PPP\PPPv3.exe
Parameters:-cs 2 -chip PIC%p -config
But the path will depend on PC and I guess what country you're in.
The easiest way to restore those two lines is click on Restore Defaults and copy then paste the other three sections.
Joel_Le_Gac
Hello, Martin,
apart from my hours of course, I took again today my problem : programs written under Flowcode v4, transferred in PIC16F877A on new cards EB006V9. In spite of my efforts, that still does not go.
Files joined : ProgTest1.fcf : source written in Flowcode V4
Pictures.rar containing :
- Folder in Program Files.jpg : folder mLoaderPIC in folder C:\Program Files\.....
- Options Compilation FCv4.jpg for Flowcode V4
- Options Project FCv4.jpg : Project options
- ProgTest1 after Compilation FCv4.jpg : it' OK !
- Compil and transfer ProgTest1 FCv4.jpg with mLoader windows : A target must be selected
- ProgTest1 Messages Compilator FCv4.jpg : error : File not sent! Return code = 51
When I load the ProgTest1.hex directly with mLoader and when I sent it to EB006V9, it's also the same : it's well transfered, but it doesn't run ! I don't understand...
With Flowcode 6 (demo version) : no problem with mLoader : file is compiled correctly and then tranfered in EB006V9 : it run correctly... But I have Flowcode V4 licence only...
Soon
Joel
Soon
Joel
- ProgTest1.hex
- (488 Bytes) Downloaded 930 times
- Pictures.rar
- (828.96 KiB) Downloaded 1017 times
- ProgTest1.fcf
- (7 KiB) Downloaded 1004 times
Hi Joel,
Problem is with your configuration settings i.e they have not been set.
That's why your program is not running at all.
For example watchdog timer is enabled by default so your program is restarting every 18ms!
Flowcode V5 and V6 has the 16F877a preconfigured, Hence program would work
Flowcode V4 does not!
First select Chip, configure.
Make sure you have not got 'Use simple config screen' enabled.
If it is then you will see: Just select 'Switch To Expert Config Screen'
Select Options then un-select 'Use simple config screen'
So now you should have: Just select correct configuration settings like this: Finally select View, project options to sect correct clock speed.
Now send to chip.
If you can't see any of the above, then maybe you can see: If you do then you just select Chip, compiler options.
Select 'Use external program to set configuration settings'
Now send to chip.
Joel_Le_Gac
Hi, Martin,
I will test it at the high school. I'll keep you informed of the results.
Soon and thanks at all.
Joel
Joel
Joel_Le_Gac
Hi, Martin,
whaoooo !!! That's all right !!!
My programs did not go because Watchdog Timer was enabled.
I have just configure PIC such as you tell me to do.
I don't know how to thank you for your assistance : thanks to your advices, you allowed me to solve this problem of communication.
Thank you thousand times.
Well cordially, Martin.
Joël
Joël
- PICmicro Configuration (expert).jpg (66.22 KiB) Viewed 44599 times
Hi Joël,
Glad you have got it working now.
While you're logged in then you can click the thumbs up icon (next to "Quote" icon) on the post that has helped you.
If you would like to thank a poster then:Joel_Le_Gac wrote:I don't know how to thank you for your assistance
Joel_Le_Gac
medelec35 wrote:Hi Joël,
Glad you have got it working now.If you would like to thank a poster then:Joel_Le_Gac wrote:I don't know how to thank you for your assistance
Thanks very much for all your help, Martin.
Joël
Moved thread to V4 section since now you are V4 registered user.
