Flash Memory Not Verified
mimiyum
Been thanked: 1 time
Post by mimiyum »
Hello, I am trying to compile to PIC16F777 and PIC16F747 using EB-006 v.6 and also HP-488 v3. First it says "The chip could not be detected. Click 'OK' to use the specified chip (16F777)" Then I get an error "Flash memory not verified - may be due to code protect"
I already configured the PIC to disable Code protect and still get the same error.
Anything we can do about this?
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Flash Memory Not Verified
Post by DavidA »
Please get the latest version of mLoader and try that. Search for mloader in our learning center.
http://www.flowcode.co.uk/lc_index.php
mimiyum
Post by mimiyum »
I downloaded and run the mloader ver 322. I get the same error. First it says "Attempting to detect chip...Unable to communicate with target: " Then later it says "Flash memory not verified - may be due to code protect"
Please see the configuration of the PIC.
PIC16F777 config.jpg (153.87 KiB) Viewed 7083 times
We are aware that the PIC16F7x7 range of devices do not currently work with our hardware. Is there a compatible chip you could use instead?
http://www.flowcode.co.uk/mmforums/viewt ... 551#p23546
If you need to use this chip then you could use a PICkit and the ICSP header on the EB006.
mimiyum
Post by mimiyum »
I need a PIC that has at least 3 PWM....that is compatible with the EB006. Any suggestions?
I don't have a PICkit.
The 16F1937 chip is the chip we supply with the v9 EB006 boards. This is a 40 pin chip and has 5 usable PWM channels.
mimiyum
Post by mimiyum »
Hello Benj,
Will the PIC16F1937 work with my EB006 v6 board?
Yes I believe the 16F1937 should be fine with the v6 EB006 board.
