Hello, I am trying to compile to PIC16F777 and PIC16F747 using EB-006 v.6 and also HP-488 v3. First it says "The chip could not be detected. Click 'OK' to use the specified chip (16F777)" Then I get an error "Flash memory not verified - may be due to code protect"
I already configured the PIC to disable Code protect and still get the same error.
Anything we can do about this?
Flash Memory Not Verified
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: Flash Memory Not Verified
Please get the latest version of mLoader and try that. Search for mloader in our learning center.
http://www.flowcode.co.uk/lc_index.php
mimiyum
- Been thanked: 1 time
I downloaded and run the mloader ver 322. I get the same error. First it says "Attempting to detect chip...Unable to communicate with target: " Then later it says "Flash memory not verified - may be due to code protect"
Please see the configuration of the PIC.
- PIC16F777 config.jpg (153.87 KiB) Viewed 7082 times
We are aware that the PIC16F7x7 range of devices do not currently work with our hardware. Is there a compatible chip you could use instead?
http://www.flowcode.co.uk/mmforums/viewt ... 551#p23546
If you need to use this chip then you could use a PICkit and the ICSP header on the EB006.
mimiyum
I need a PIC that has at least 3 PWM....that is compatible with the EB006. Any suggestions?
I don't have a PICkit.
The 16F1937 chip is the chip we supply with the v9 EB006 boards. This is a 40 pin chip and has 5 usable PWM channels.
Yes I believe the 16F1937 should be fine with the v6 EB006 board.
