PWM Arduino MEGA
A forums to allow bugs and problems with Flowcode v6 to be reported and resolved.
cubitus54
Flowcode v5 User
Has thanked: 7 times
Been thanked: 32 times
PWM Arduino MEGA
Post by cubitus54 »
Wrong !
(63.46 KiB) Downloaded 2593 times
Flowcode V6.1.2.0(11 05 2015)
Re: PWM Arduino MEGA
Is your clock speed setup correctly in the project options? If you do a one second flasher loop then are the delays on the hardware coming out as 1 second?
http://www.flowcode.co.uk/wiki/index.php ... ED_flasher
cubitus54
Flowcode v5 User
Post by cubitus54 »
On the cards Adruino Mega (2560 R3) the clock is set to 16MHz it can not be changed in "projet" :?
Looking at the ATMEGA2650 datasheet the equation is like this.
FoscPWM = 16000000 / (2 * 1 * 101) = 12.625us Period
However if your hardware is running differently then it could be we have missed something. I will see if I can dig out a Arduino Mega 2560 to test.
cubitus54
Flowcode v5 User
Post by cubitus54 »
It's more serious than that. The value "period" has no effect on the output frequency.
It looks like the period overflow is not working as it should be and is defaulting to 256.
16000000 / (2 * 1 * 256) = 32us Period
Looking deeper it appears that the ATMEGA2560 does not have the registers to allow for variable PWM period. I will see if we can add a warning message to the output to inform the user when this happens.
AVR_CAL_PWM.c
(19.49 KiB) Downloaded 408 times
cubitus54
Flowcode v5 User
Post by cubitus54 »
C:\Program Files (x86)\Flowcode\V6\CAL\/AVR\AVR_CAL_PWM.c:550: error: conflicting types for 'FC_CAL_PWM_ChangePeriod_1'
Ah sorry yes there have been other recent PWM changes. Hmm.
Here are the latest component files.
PWM.fcpx
(7.8 KiB) Downloaded 405 times
cal_pwm.fcpx
(8.08 KiB) Downloaded 370 times
cubitus54
Flowcode v5 User
Post by cubitus54 »
it's better
Thank You
cubitus54
Flowcode v5 User
Post by cubitus54 »
I made a PWM function that works. :mrgreen:
But there is a bug that I do not understand ...
Exemple :
MX_UINT8 FCL_CS1 = (0x0);
MX_UINT16 FCL_RC = (0x0);
MX_UINT16 FCL_DIV = (0x0);
.div = 16000
.RC = (.Rapport_cyclique * .div) / 100
.RC = 8000
OCR1B = FCL_RC; Wrong (the real value is about 500 max)) :?: :?: :?: :?:
If I put the value directly
OCR1B = 8000; is OK
(49.98 KiB) Downloaded 2524 times
(59.33 KiB) Downloaded 2524 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Looking at the information in your message:
That 16 bit variable can hold a value of 0 to 65535.
The formula:
.div = 16000
And in your debug window:
.Rapport_cyclique = 50
This results in .RC = (50 * 16000) / 100, which means the controller will first calculate 50 * 16000 = 800000. This is very much > 65535 so the result will become 800000 % 65536 = 13568 (only the remainder is kept, the overflow is discarded), which will be divided by 100, results in .RC = 135. You need to use either a MX_UINT32 (long) for .RC or restructure the calculation to make sure the (intermediate) result does not exceed the maximum value of your data type.
Simulation is not a 100% match for what happens on the controller.
― C.S. Lewis
cubitus54
Flowcode v5 User
Post by cubitus54 »
I tried, it does not change ...
PWM.fcfx
(6.87 KiB) Downloaded 348 times
kersing
Post by kersing »
Change .div to a long as well.
The formula:
.div = 8000000 / .Frequence
Has the same problem with .div being an 16 bit (unsigned) integer.
― C.S. Lewis
cubitus54
Flowcode v5 User
Post by cubitus54 »
sorry
But I think there is no problem ...
What matters here is the result variable div, the result of the operation will not exceed 16 bits.
kersing
Post by kersing »
Try it to make sure you are right.
Or take a look at the generated assembler code to make sure that is not a problem. I think you will find the compiler generates a sequence where it loads the (too large) value in a 16 bit register and perform the division next. (Another solution could be to use 8000000l in the formula to force the compiler to use 32 bit while performing the calculation.)
― C.S. Lewis
cubitus54
Flowcode v5 User
Post by cubitus54 »
OK. Sorry! You were right: oops:: roll:
To make this work we had put in the 32-bit variable .div
