RS232 Pins & Console
A forums to allow bugs and problems with Flowcode v6 to be reported and resolved.
Bachman
Has thanked: 9 times
Been thanked: 53 times
Post by Bachman »
Hello!
Flowcode show wrong pins, but the HW uses the correct ones.
Sending 0 (zero) via RS232, the information not shown in the console.
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: RS232 Pins & Console
Post by dazz »
Hi Bachman
Ive attached an fcdx for that chip, rename the one in your fcd folder and paste the attached one in, i cant test it as i don't have that chip on hand.
Can you then post back here if it's ok
Dazz
PLEASE FIND NEW ATTACHMENT FURTHER DOWN
18F1320.fcdx
(21.38 KiB) Downloaded 310 times
Bachman
Post by Bachman »
Thank you!
The properties window is ok, only the chip name is too long. The console problem must be in the Flowcode, i think.
Hi Bachman,
Bachman wrote:Sending 0 (zero) via RS232, the information not shown in the console.
When you use SendChar you need to look on the ASCII Table for the char being sent e.g 1 then look at the Dec number and send that value.
In the case of 1 you need to
SendChar(49)
If you want to send 0 then you use
SendChar(48)
(36.1 KiB) Downloaded 3295 times
An easier way to send a number is to send it as a string e.g SendString "0"
If you want to send a variable value e.g if VariableValue = 128
Then you could create a string then convert variable to a string then send the string:
(31.81 KiB) Downloaded 3295 times
Bachman
Post by Bachman »
Yes, it's a solution for the bug. If i convert the numbers into ASCII, i need extra steps on the RX side to convert it back to numbers. Sending zero via UART works fine in the HW, the bug "visible" only in the simulation.
dazz
Post by dazz »
HI Bachman
Sorry about the name i used it for checking and forgot to remove the extra numbers (doh).
I have corrected and reattached to this post
Dazz
18F1320.fcdx
(21.38 KiB) Downloaded 349 times
Bachman wrote:Yes, it's a solution for the bug. If i convert the numbers into ASCII, i need extra steps on the RX side to convert it back to numbers. Sending zero via UART works fine in the HW, the bug "visible" only in the simulation.
You don't need the extra steps to just send a 0.
Either sendChar(48)
or
SendString"0"
If you use SendChar(0) then that's a null character, not a 0.
So its just the termination of the string
The extra steps are only If sending a byte variable.
Bachman
Post by Bachman »
This is why i send 0, not "0".
