18F887 UART - MAX 485 - USB RS485 - PC PROBLEM
asbase
Has thanked: 13 times
Post by asbase »
Hello, my 887 waiting data to be input from pc, after input then re output again to pc terminal(realterm) but the output length always short by 2 byte. please help.
Thank you.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: 18F887 UART - MAX 485 - USB RS485 - PC PROBLEM
Post by kersing »
If your flowchart does not work as expected and you want help with it you need to post your flowchart. Our crystal ball has worn out long ago and our psychic abilities are not what they used to be either. ;-)
Use the "Upload attachment" TAB below the "Submit" button to attach files to forum messages.
― C.S. Lewis
asbase
Post by asbase »
Simple LED Flashing work in fc5 but not in real hardware
(528.41 KiB) Downloaded 1695 times
kersing
Post by kersing »
As requested previously, please attach your flowchart, a screen shot is not a flow chart, so we can look at it.
― C.S. Lewis
asbase
Post by asbase »
File Attached.
TEST.fcf
(8 KiB) Downloaded 511 times
