Hello, my 887 waiting data to be input from pc, after input then re output again to pc terminal(realterm) but the output length always short by 2 byte. please help.
Thank you.
18F887 UART - MAX 485 - USB RS485 - PC PROBLEM
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: 18F887 UART - MAX 485 - USB RS485 - PC PROBLEM
If your flowchart does not work as expected and you want help with it you need to post your flowchart. Our crystal ball has worn out long ago and our psychic abilities are not what they used to be either.
Use the "Upload attachment" TAB below the "Submit" button to attach files to forum messages.
― C.S. Lewis
― C.S. Lewis
asbase
- Has thanked: 13 times
Simple LED Flashing work in fc5 but not in real hardware
- Simple LED Flashing work in fc5 but not in real hardware
- (528.41 KiB) Downloaded 1695 times
kersing
As requested previously, please attach your flowchart, a screen shot is not a flow chart, so we can look at it.
― C.S. Lewis
― C.S. Lewis
asbase
File Attached.
- TEST.fcf
- (8 KiB) Downloaded 595 times
