I've created the same project using Flowcode 5.5 and Flowcode 6.1.2.0 and the PWM works correctly. The hex file is correct and the testing device works.
But using Flowcode 6.1.3.2 the PWM stops working.
I would ask you for quick help with this issue / bug.
[solved] BUG in FLOWCODE 6.1.3.2 PWM in PIC16F1933 no work
JustinS
- Flowcode v5 User
- Has thanked: 1 time
- Been thanked: 7 times
- pic16f1933_v6.fcfx
- Flovcode 6.1.3.2
- (3.34 KiB) Downloaded 629 times
JustinS
- Flowcode v5 User
Re: [solved] BUG in FLOWCODE 6.1.3.2 PWM in PIC16F1933 no w
Thank you. But it didn't work
What did (The Solution):
1. I copied PIC_CAL_PWM.c from FlowCode 6.1.2.0.
2. Changed the definition and declaration of function FC_CAL_PWM_ChangePeriod_ from using MX_UINT8 for 'period' parameter to MX_UINT16. Otherwise it would not compile.
PS: I don't know if I didn't cause some other issues for myself in the future, but for now it works.
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Thanks for letting us know you now have a solution.
I've tested the latest files in my 6.1.3.2 installation and all seems well.
So I’ve attached the latest PWM files, just in case you (or anyone else) wants to try these, if so replace all three.
The PIC_CAL_PWM.c file goes into (Flowcode 6 install directory)\CAL\PIC
The component files *.fcpx go into (Flowcode 6 install directory)\components
Probably best to move the old versions to a backup first.
Note: Do not just rename the old *.fcpx files in the install directory, Flowcode might still pick up the old version, as it uses a GUID to identify the components.
- PWM.fcpx
- (7.82 KiB) Downloaded 571 times
- cal_pwm.fcpx
- (8.23 KiB) Downloaded 529 times
- PIC_CAL_PWM.c
- (14.18 KiB) Downloaded 638 times
JustinS
- Flowcode v5 User
Thank you for your solution. It works... but only for one PWM. When we added another one we started to get the following error during compilation:
pic16f1933_v6b.c(344): Illegal redefinition of symbol: MX_PWM_PERIOD
- pic16f1933_v6b.fcfx
- (5.87 KiB) Downloaded 493 times
- LeighM
Thanks for the spot.
try this update ..
try this update ..
- cal_pwm.fcpx
- (8.22 KiB) Downloaded 534 times
