[solved] BUG in FLOWCODE 6.1.3.2 PWM in PIC16F1933 no work
JustinS
Flowcode v5 User
Has thanked: 1 time
Been thanked: 7 times
Post by JustinS »
I've created the same project using Flowcode 5.5 and Flowcode 6.1.2.0 and the PWM works correctly. The hex file is correct and the testing device works.
But using Flowcode 6.1.3.2 the PWM stops working.
I would ask you for quick help with this issue / bug.
pic16f1933_v6.fcfx
Flovcode 6.1.3.2
(3.34 KiB) Downloaded 628 times
Has thanked: 481 times
Been thanked: 699 times
Re: BUG in FLOWCODE 6.1.3.2 PWM in PIC16F1933 no work
JustinS
Flowcode v5 User
Has thanked: 1 time
Re: [solved] BUG in FLOWCODE 6.1.3.2 PWM in PIC16F1933 no w
Post by JustinS »
Thank you. But it didn't work :(
What did (The Solution):
1. I copied PIC_CAL_PWM.c from FlowCode 6.1.2.0.
2. Changed the definition and declaration of function FC_CAL_PWM_ChangePeriod_ from using MX_UINT8 for 'period' parameter to MX_UINT16. Otherwise it would not compile.
PS: I don't know if I didn't cause some other issues for myself in the future, but for now it works.
Thanks for letting us know you now have a solution.
I've tested the latest files in my 6.1.3.2 installation and all seems well.
So I’ve attached the latest PWM files, just in case you (or anyone else) wants to try these, if so replace all three.
The PIC_CAL_PWM.c file goes into (Flowcode 6 install directory)\CAL\PIC
The component files *.fcpx go into (Flowcode 6 install directory)\components
Probably best to move the old versions to a backup first.
Note: Do not just rename the old *.fcpx files in the install directory, Flowcode might still pick up the old version, as it uses a GUID to identify the components.
PWM.fcpx
(7.82 KiB) Downloaded 570 times
cal_pwm.fcpx
(8.23 KiB) Downloaded 528 times
PIC_CAL_PWM.c
(14.18 KiB) Downloaded 638 times
JustinS
Flowcode v5 User
Has thanked: 1 time
Post by JustinS »
Thank you for your solution. It works... but only for one PWM. When we added another one we started to get the following error during compilation:
pic16f1933_v6b.c(344): Illegal redefinition of symbol: MX_PWM_PERIOD
pic16f1933_v6b.fcfx
(5.87 KiB) Downloaded 493 times
Thanks for the spot.
try this update ..
cal_pwm.fcpx
(8.22 KiB) Downloaded 534 times
JustinS
Flowcode v5 User
Has thanked: 1 time
Post by JustinS »
Thank your for a quick replay. It compiles now :D
