Variable Bit Error
Variable Bit Error
Bit variable behaves as a byte....
- I declare a variable of 1 bit
- 0 Перем.jpg (100.88 KiB) Viewed 17976 times
- Flowcode showed a 1 bit
- (173.27 KiB) Downloaded 815 times
- Proteus showed a byte
- (221.66 KiB) Downloaded 815 times
Re: Variable Bit Error
I did this device.
The real variable - BYTE !!!
- BUG.fcfx
- Program
- (6.38 KiB) Downloaded 524 times
- The device itself
- 3 Плата.jpg (160.23 KiB) Viewed 17976 times
- Oscilloscope
- 4 Осцил.jpg (181.84 KiB) Viewed 17976 times
Hi Osta,
BoostC did not support bit variables so we simply made a bool equal to a byte.
XC8 does support bit variables so the attached code should solve the problem your having.
The file lives in the "Flowcode 7/CAL/PIC" directory.
Hi Benj!
Yes! Now it works.
Now it is necessary to add the COF file ..
Regards Slava.
Yes! Now it works.
Regards Slava.
Hi Slava,
The PIC XC8 compiler should automatically create the .cof files as part of the compile process.
I've found a bit of a bug concerning the last update and may explain things. Anyway it seems to have broken other parts of the code so I am investigating this now.
Here's the original file if you need to go back.
Looks like to use the bool type as a macro parameter it cannot be a bit in the C code for 8-bit PIC. The compiler will likely use a full byte memory location for each bit variable anyway (unless combined into a struct) so even if we are using byte in the C code it should not have any impact on code efficiency.(698) bit variables must be global or static
Thanks Benj!
I will leave as is, since other functions are working properly.
For example, select the team (if) does not always work correctly.
Regards Slava.
Regards Slava.
