I2C ACK
Alan_37
Has thanked: 51 times
Been thanked: 54 times
I2C ACK
Post by Alan_37 »
I have this issue when communicating with DS1307 RTC
When receiving ACK after D1 flowcode is outputing this as a NACK (1) insted of 0 .
All other Conditions are Correct only the Ack after D1 is incorrect any ideas what can this be ?
(104.13 KiB) Downloaded 1368 times
Alan_37
Re: I2C ACK
Post by Alan_37 »
I am continuing to experiment with the intent to help find the problem
below is a waveform of the I2c Protocol sending the same data only this time the data is not
a Read from device command (or condition ) this time flowcode gets the ACK Correct .
The only difference i can see is that the SDA go High exactly after the ACK is Revived .
(99.36 KiB) Downloaded 1350 times
Alan_37
Re: I2C ACK
Post by Alan_37 »
Here is another update the problem seems to be only when receiving ACK after the Read Command
below is the waveform of the i2c when Reading from MCP4725 DAC .
Flowcode Gets the ACK Wrong this time outputing it as logic 1 (NACK) .
Hope this will help to find a solution to this problem as soon as possible .
(113.54 KiB) Downloaded 1350 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: I2C ACK
Post by LeighM »
Could you attach your program?
Are you using I2C Master component?
When using the ReceiveByte macro you need to set the "Last" parameter, either 0, or 1 if no more data is to be requested, this will cause a NAK.
Alan_37
Re: I2C ACK
Post by Alan_37 »
Hi LeighM
Thanks for your quick reply.
So yes I am using I2C Master the ACK in question is being produced by the Renter of the TRANSMIT BYTE ,
it happens only when transmitting the Read command . from the logic Analyzer I am able to see that an ACK
is being sent back from the device to the MCU , but flowcode returns this as a NACK .
The Project is a RS232 to I2c interface if you need a copy I will PM it to you .
But I think this is not necessary because it happens on all devices when Sending the Read Command .
Thanks in Advance
Alan
LeighM
Re: I2C ACK
Post by LeighM »
So when you say "outputing it as logic 1" do you mean that the Flowcode TransmitByte macro is returning a 1 (to indicate Nack received from the device)?
What is your target processor?
And I presume you are using a hardware channel?
Alan_37
Re: I2C ACK
Post by Alan_37 »
Yes exactly that is what i meant the TransmitByte macro is returning a 1 when it should return a 0 .
The Target MCU is an ATMEGA2560 ( ARDUINO MEGA2560 R3 ) , also yes I am using hardware channel
I tried to experiment whit the I2C component settings with the intent of fixing the problem but to no avail.
it means that the problem is also present with the default I2c Component Settings.
(12.65 KiB) Downloaded 3920 times
LeighM
Re: I2C ACK
Post by LeighM »
Just as a test, could you try disabling Slew and SMB, if you have not tried that already?
Might be worth PMing your code if you could please.
Meanwhile I'll take a look at the CAL code.
Alan_37
Re: I2C ACK
Post by Alan_37 »
HI LeighM
Just tried to disable SMbus and Slew Rate the problem still remains .
Alan_37
Re: I2C ACK
Post by Alan_37 »
Hi LeighM
Here is a very simple Program i made now , when sending TEST to RS232 it
will Read the time registers from DS1307 RTC , but it first Sends the ACKS and NACK Received
on every Byte Transmitted .
The DS1307 Register byes dose not match the logic Analyzer cause it was taken at a different time .
But this should clearly show the BUG when sending D1 ( Read Command ) .
(382.48 KiB) Downloaded 1314 times
Dev.rar
(57.11 KiB) Downloaded 389 times
