Webserver Wiznet SPI Connections default to hardware
A forums to allow bugs and problems with Flowcode v7 to be reported and resolved.
Jay Dee
Has thanked: 121 times
Been thanked: 154 times
Post by Jay Dee »
Hi Guys,
The WebServer components SPI pin settings seem to revert to default Hardware pins, after loading up FC file for editing, even though they are shown as the correct software SPI pins in FC7.
I am using an ECIO40P + Wiz810MJ.
If I load and then compile the program it outputs SPI data on the hardware SPI pins.
If in FC7 I toggle the SPI Hardware/software option and re-enter my software pins, save, compile to chip... all good.
Save, close, reopen...compile to chip and problem is back again.
My software pins are...
MOSI C7
MISO C6
CLK C2
CS C1
Int C0
See attached FC.
Regards, J.
Wiznet_BasicTest.fcfx
(12.88 KiB) Downloaded 257 times
Re: Webserver Wiznet SPI Connections default to hardware
Thanks for letting us know.
I believe I have fixed it with the attached updated component. Simply copy to your "Flowcode 7/components" directory and restart Flowcode.
Webserver_EB023_00_2.fcpx
(25.33 KiB) Downloaded 289 times
Let me know how you get on.
Jay Dee
Post by Jay Dee »
Affirmative, Looks good so far. Thanks for quick response Ben.
J.
