Hi Guys,
The WebServer components SPI pin settings seem to revert to default Hardware pins, after loading up FC file for editing, even though they are shown as the correct software SPI pins in FC7.
I am using an ECIO40P + Wiz810MJ.
If I load and then compile the program it outputs SPI data on the hardware SPI pins.
If in FC7 I toggle the SPI Hardware/software option and re-enter my software pins, save, compile to chip... all good.
Save, close, reopen...compile to chip and problem is back again.
My software pins are...
MOSI C7
MISO C6
CLK C2
CS C1
Int C0
See attached FC.
Regards, J.
Webserver Wiznet SPI Connections default to hardware
- Wiznet_BasicTest.fcfx
- (12.88 KiB) Downloaded 256 times
Re: Webserver Wiznet SPI Connections default to hardware
Thanks for letting us know.
I believe I have fixed it with the attached updated component. Simply copy to your "Flowcode 7/components" directory and restart Flowcode.
Let me know how you get on.
