PIC16F1824 PWM
Re: PIC16F1824 PWM
I Have moved topic from Fixed bugs to Bug reports.
Compiles for me ok:
As a complete guess, Perhaps it is something to do with language settings?
Have you tried changing to English and seeing it it will compile for you?
Compiles for me ok:
Device: PIC.16F.16F1824
Generated by: Flowcode v7.2.1.4
Date: Sunday, August 27, 2017 20:20:51
Users: 1
Registered to: Martin
Licence key: BA48R5
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe --chip=16F1824 "TX.c" --MSGDISABLE=359,1273,1388
Microchip MPLAB XC8 C Compiler (Free Mode) V1.41
Build date: Jan 24 2017
Part Support Version: 1.41
TX.c: 191: (1257) local variable "_FCR_RETVAL" is used but never given a value (warning)
Memory Summary:
Program space used BFh ( 191) of 1000h words ( 4.7%)
Data space used 24h ( 36) of 100h bytes ( 14.1%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Data stack space used 0h ( 0) of DBh bytes ( 0.0%)
Configuration bits used 2h ( 2) of 2h words (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
You have compiled in FREE mode.
Using Omniscient Code Generation that is available in PRO mode,
you could have produced up to 60% smaller and 400% faster code.
See http://www.microchip.com/MPLABXCcompilers for more information.
C:\Program Files (x86)\Flowcode 7\tools\DoNothing\DoNothing.exe
FINISHED
Re: PIC16F1824 PWM
If I remove the delay, then everything is fine ...
- Del.jpg (94.96 KiB) Viewed 22989 times
Re: PIC16F1824 PWM
Take a look at how much program space your flowchart is using when you compiled it (99.7%) compared to when I compiled it (4.7%) and that was with the delay!
The Reason your first flowchart did not compile was due to using too much program space.
Not sure how such a small flowchart can use up lots of rom when you try to compile, but not when I compile it?
Re: PIC16F1824 PWM
Yes, I noticed it!
But I can not understand why.
EDIT:
Rearranged the program.
And checked with every update.
That's what happened .... EDIT2:
It turns out that the last update introduces an error in the compiler.
EDIT:
Reason: Please, use edit button to edit your old message instead. It makes the topic much easier to read! :)
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: PIC16F1824 PWM
Updated PWM component attached,
to go into Flowcode7\components directory.
This should reduce the download code size
- PWM.fcpx
- (8.96 KiB) Downloaded 623 times
Re: PIC16F1824 PWM
Thanks for the correction!
Yes, the code has become smaller.
But the simulation indicator remained.
- ZZZ.jpg (51.75 KiB) Viewed 22844 times
Re: PIC16F1824 PWM
Hi LeighM !!
I did not know about it.
I apologize.
Everything else works !!!
Thank you!!!!!!!!
I apologize.
Thank you!!!!!!!!
