Analog Component Error
alanwms
Has thanked: 4 times
Been thanked: 17 times
Post by alanwms »
The error below comes up when compiling to hex. The program works fine, and the component pins ARE actually connected. Is there an explanation for this?
analog Error.jpg (45.07 KiB) Viewed 3295 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Analog Component Error
Post by kersing »
Please post your flowchart... Debugging these errors is difficult without sufficient information and the flowchart contains a lot of information.
If I had to hazard a guess, you have more analog components added and one of them has unconnected pins.
― C.S. Lewis
alanwms
Post by alanwms »
Two channels were assigned to An3 (one was flow - which was mine) one of those channels automatically has some "pot_chicken_Pie" name which was confusing. I had added a different one (flow), and subsequently removed pot_chicken_whatsit due to your suggestion. Problem solved.
The help button takes me to a non page so it's learn by fire after switching from 5 to 7.
Is the link broken or is there something you can suggest we can do to improve the wiki landing page?
