UART Issues
cubetronix
UART Issues
Iam Using PIC18F67J11 Chip with external 20MHz Crystal between OSC1 & OSC2.
first step i checked a blink circuit it worked fine
second i added with UART-1 with Baud 9600 a simple string to Transmit while startup, but i cant receive a string and there are some JUNK in the RX window. I feel that Config Bits are not properly assigned. Kindly help with this
Thank You,
Thank You,
Re: UART Issues
Please can you attach your Flowcode project file so we can investigate for you.
cubetronix
Re: UART Issues
Benj wrote:Hello,
- test-1.fcfx
- (9.86 KiB) Downloaded 272 times
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: UART Issues
Looking at your Flowchart the baud is not set at 9600 it is set at 115200cubetronix wrote: i added with UART-1 with Baud 9600 a simple string to Transmit while startup, but i cant receive a string and there are some JUNK in the RX window.
In general if you are not clearing the Watchdog timer you should switch it off ,this can cause you some strange errors I do not see in your flowchart that you clear the Watchdog
you should also make sure your Oscillator settings are correct this device has a tricky setup for the Oscillator as general info to a UART that does not work
Regards QMESAR
Regards QMESAR
cubetronix
Re: UART Issues
QMESAR wrote:Looking at your Flowchart the baud is not set at 9600 it is set at 115200cubetronix wrote: i added with UART-1 with Baud 9600 a simple string to Transmit while startup, but i cant receive a string and there are some JUNK in the RX window.
Thanks for your prompt reply,
I know the baud rate is changed, yesterday i was trying with it and forget to change before sharing it,
the problem is same if i use any baud rate. and i want to know as per datasheet
Oscillator Types are
The PIC18F87J11 family of devices can be operated in
eight different oscillator modes:
1. HS High-Speed Crystal/Resonator
2. HSPLL High-Speed Crystal/Resonator
with Software PLL Control
3. EC External Clock with FOSC/4 Output
4. ECPLL External Clock with Software PLL
Control
5. INTIO1 Internal Oscillator Block with FOSC/4
Output on RA6 and I/O on RA7
6. INTIO2 Internal Oscillator Block with I/O on
RA6 and RA7
7. INTPLL1 Internal Oscillator Block with Software
PLL Control, FOSC/4 Output on RA6
and I/O on RA7
8. INTPLL2 Internal Oscillator Block with Software
PLL Control and I/O on RA6 and RA7
but in flow code7 Oscillator Types
HS USB-HS
HS + PLL HS-USB HS +PLL
i am using 20 MHz external crystal so in which mode i have to use
Thank You
cubetronix
cubetronix
Re: UART Issues
I found some compilation error before regarding XC8 and updated the XC8 from microchip now i found this warning, can some one help to resolve this. below is the compilation result for reference.
Target folder: G:\FLOW CODE\Projects\serial test
Source name: G:\FLOW CODE\Projects\serial test\serial test.fcfx
Title:
Description:
Device: PIC.18F.18F66J11
Generated by: Flowcode v7.2.1.4
Date: Friday, February 02, 2018 20:03:46
Users: 1
Registered to:
Licence key:
NOT FOR COMMERCIAL USE
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe --chip=18F66J11 "serial test.c" --MSGDISABLE=359,1273,1388
Microchip MPLAB XC8 C Compiler (Free Mode) V1.41
Build date: Jan 24 2017
Part Support Version: 1.41
serial test.c:
34: __config("__PROG_CONFIG", "pic18", 0x1, 0xFFFF);
^ (1504) the PIC18 extended instruction set was enabled but is not supported by this compiler
(908) exit status = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe reported error code 1
FINISHED
Title:
Description:
Users: 1
Registered to:
Licence key:
serial test.c:
FINISHED
- QMESAR
Re: UART Issues
Hi.
Try to Switch the Extended CPU instruction set off,
Regards QMESAR
Regards QMESAR
cubetronix
Re: UART Issues
Thanks for the reply, after disabling the extended CPU UART is working but only TX, i cant receive anything with or without interrupt. kindly check the flowcode.QMESAR wrote:Hi.
Thank You
- QMESAR
Re: UART Issues
Hi .
I see no problem with the Flowchart or the generated C code.
However not saying there is no error unfortunate I do not have such an device to test on HW
Are using real HW to test or Simulation in FC? (just a reminder FC does not simulate UART Interrupts)
Regards QMESAR
Regards QMESAR
cubetronix
Re: UART Issues
i am using real HW.QMESAR wrote:Hi .
Re: UART Issues
In your UART_1 macro you need to call the ReceiveChar component macro to clear the UART RX buffer. Otherwise it may overflow and prevent more data coming in.
