need help
need help
hi
i am new user for flowcode i need to run lcd 16 * 2 with pic 16f877 with keybad i need when to print number stay at its
position and the other numuber in the next digit and so on until the 32 characters displayed when hit the keybad
Re: need help
Hi jafal,
Welcome to the forums.
If it was me, I would use a count variable (initial value = 0) that increments each time a key is pressed.
Then use a discussion branch:.
Finally use function
If you become stuck then post Flowchart and I will help you further.
It's highly recommended to learn from the Learning centre found under support menu of the forums.
If count = 17 then LCD cursor x=0, y=1Finally use
LCD PrintNumberIf you become stuck then post Flowchart and I will help you further.
Re: need help
hi sir
thanks for replay
if you pleas post to me the flow chart of all project
show me how to do it i am trying to train
thanks for replay
Re: need help
hi sir
this is my attempt i am very new
thanks alot
thanks alot
- Flowcode1.fcf
- (9.5 KiB) Downloaded 482 times
Re: need help
Attached is one way.
As you said 2x16 I have changed it to that LCD.
I have also changed target device to 16F877.
If you want to make it do something in addition, then see if you can modify it and upload back on this thread.
- LCD Keypad a.fcf
- (10 KiB) Downloaded 533 times
Re: need help
hi sir
thanks very much again the cfc file did not open iam using the demo flow code i think its work just on 16f877a not 16f877
if its not hard for you and if you pleas can you modifies the 16f877 to 16f628a and iam very thankful for your co-operation
many thanks for you
many thanks for you
Re: need help
Done!
- LCD Keypad 16F628A .fcf
- (10 KiB) Downloaded 460 times
Re: need help
hi sir
thanks a lot it works
thanks for your help
i am going to try some stuffs with this project and i am going to need farther help from you
many thanks
many thanks
Re: need help
medelec35 wrote:You're welcome.
Thanks for letting me know.
hi sir
while i am trying to compile the file to hex i received this massage ..
File name: C:\Users\jafal\Desktop\flownew\LCD Keypad 16F628A (1).c
Launching the compiler...
C:\Program Files\Flowcode\v5\Tools\boostc\boostc_pic16_flowcode.exe -v -t PIC16F628A "LCD Keypad 16F628A (1).c"
BoostC Optimizing C Compiler Version 7.04 (for PIC16 architecture)
http://www.sourceboost.com
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Starting preprocessor: C:\PROGRA~1\Flowcode\v5\Tools\boostc\pp.exe "LCD Keypad 16F628A (1).c" -i C:\PROGRA~1\Flowcode\v5\Tools\boostc\include -d _PIC16F628A -la -c2 -o "LCD Keypad 16F628A (1).pp" -v -d _BOOSTC -d _PIC16 -d _CHAR_INDEX
LCD Keypad 16F628A (1).c(580): error: missing right paren
LCD Keypad 16F628A (1).c(580): error: missing semicolon
LCD Keypad 16F628A (1).c(574): error: failure
failure
.......Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
FINISHED
the fcf of my file was compiled successfully
whats gone wrong with me ??
regaeds
Re: need help
Sorry,
I should of mentioned you need to assign your own connections to keypad.
On the panel, right click on the keypad & select Connections.
Make sure there are no Unconnected showing so you must assign every connection.
If there are any Unconnected showing then when compiling to hex or chip, you will get
Note If you are going to use the chip you have stated then, you will not be able to use a crystal to drive it.
It must be changed to use internal oscillator.
To use internal oscillator, a C code block must be placed at the very start of main with an osccon value within it.
See this post to select correct value.
Although 16F628a can't go as high as 32MHz.
Also you can't use RA5 for LCD as it's an input only.
Alternatively you can use 16F1937 as that is allowed with the free version.
All free version microcontrollers:
LCD Keypad 16F628A (1).c(574): error: failureIt must be changed to use internal oscillator.
: 16F84A, 16F628A, 16F690, 16F88, 16F877A, 16F887, 16F1937, 18F4431, 18F2220, Formula Flowcode Buggy, ECIO-40, ECIO-28, MIAC, Locktronics PICMartin
Re: need help
hi sir again
its hard to find but those pics in my country 16f877/a 16f628 and 2 or three of 18f"sxxxxxx
i did not got it that i cant use the out Crystal
if i used the hex that i complied directly to chip wont work ?
if you plz explain to my how to run this project on chip
Re: need help
hi sir
do you mean like this project ?
- jafal2.fcf
- (7.5 KiB) Downloaded 442 times
Re: need help
hi sir
at the start of flowchart i have to put this in order to control the frequency with out external crystal
osccon=0x78; // 32Mhz (4xPPL+4meg)
is that your point ?
Re: need help
I did state:jafal wrote:at the start of flowchart i have to put this in order to control the frequency with out external crystal
You will need to download the datasheet for 16F628A.medelec35 wrote:Although 16F628a can't go as high as 32MHz.
use Ctrl F to search datasheet for osccon
You should see a page similar to the page shown in the link I posted.
There you should see all the frequencies that can be used.
Once you have found your desired frequency then calculate correct osccon value.
Best advice when developing any project is to do the one second flasher test!
Re: need help
hi sir
i understand now thanks for your help
if i want to use 12864 lcd what should i do to move the cursor from first digit to last digit
with 16 * 2 was
how to do it with 12864
thanks in advance
regardes
with 16 * 2 was
thanks in advance
regardes
Re: need help
Sorry I don't know if flowcode V5 supports 12864 lcd.jafal wrote:if i want to use 12864 lcd
Re: need help
Good morning sir
I have try a lot to print the numbers on lcd 16 * 4 but each time i got bad results i couldn't control the digit in the exact
place help me how to print using lcd 16 * 4
Re: need help
Sorry unable tell from that.
Can't help without a flowchart.
Only if you want to keep it private then you pm it.
Re: need help
medelec35 wrote:Sorry unable tell from that.
hi
this is the flowchart
- Flowcode1 - Main.JPG (25.72 KiB) Viewed 22171 times
