Update Windows 10 and bug compiler HEX
waligator
Has thanked: 5 times
Been thanked: 7 times
Post by waligator »
Hi all,
Since the last update of Windows 10 (version 1803), the compiler HEX no longer stops. He never ends.
I uninstalled, reinstalled the program, no changes
What should I do ?
waligator
Re: Update Windows 10 and bug compiler HEX
Post by waligator »
No one had this problem ?
The problem is the same with Flowcode V6
The only time I have that problem is when my kaspersky antivirus is running as it does not like Boostc!
Sounds like an antivirus, firewall or other windows application is not allowing BoostC to run
This sorted the issue out for me
waligator
Post by waligator »
hello Martin,
I disabled avast and windows defender. it does not change anything :(
Do you run a firewall like comodo?
waligator
Post by waligator »
no, the firewall is intergrated with avast.
The C code is well transcribed. It's just the next step that goes around in circles without giving any error
If you post your Flowchart,
I will see if it will compile for me.
waligator
Post by waligator »
This is one of the first code I wrote several years ago. After 5 minutes, the compiler did not finish. I canceled manually
Test led 876.fcf
(12 KiB) Downloaded 573 times
I'm running 64 bit windows 10 and only took a few seconds to compile
File name:     D:\Statments\Test led 876.c
Title:
Description:
Generated by:  Flowcode v5.5.2.1
Date:          Wednesday, May 09, 2018 21:12:47
Licence:       Professional
Registered to: Martin
Licence key:   xxxxx
Launching the compiler...
C:\Program Files (x86)\Flowcode\v5\Tools\boostc\boostc_pic16_flowcode.exe -v -t PIC16F876A "Test led 876.c"
BoostC Optimizing C Compiler Version 7.04 (for PIC16 architecture)
http://www.sourceboost.com
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Test led 876.c
Starting preprocessor: C:\PROGRA~2\Flowcode\v5\Tools\boostc\pp.exe "Test led 876.c" -i C:\PROGRA~2\Flowcode\v5\Tools\boostc\include -d _PIC16F876A -la -c2 -o "Test led 876.pp" -v -d _BOOSTC -d _PIC16 -d _CHAR_INDEX
Test led 876.c success
success
Return code = 0
C:\Program Files (x86)\Flowcode\v5\Tools\boostc\boostlink_pic.exe -ld "C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib" libc.pic16.lib rand.pic16.lib float.pic16.lib "Test led 876.obj" -t PIC16F876A -d "D:\Statments" -p "Test led 876"
BoostLink Optimizing Linker Version 7.03
Warning unreferenced functions removed:
	 FC_CAL_Port_In__x	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_IO.c
	 FC_CAL_Port_In_DDR__x	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_IO.c
	 FC_CAL_Port_Out__x	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_IO.c
	 FC_CAL_Port_Out_DDR__x	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_IO.c
	 Wdt_Delay_S	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
	 Wdt_Delay_Ms	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
	 FCI_DELAYINT_US	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
	 FCI_DELAYINT_MS	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
	 FCI_DELAYINTWDT_MS	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
	 FCI_DELAYINT_S	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
	 FCI_DELAYINTWDT_S	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
	 FCI_GETCHAR	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_GETLENGTH	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_MIDSTRING	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_LEFTSTRING	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_RIGHTSTRING	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_TOSTRING	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_TOLOWER	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_TOUPPER	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_COMPARE	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_FLOAT_TO_STRING	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_NUMBER_TO_HEX	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_STRING_TO_INT	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_STRING_TO_FLOAT	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_STRREV	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_STRMOV	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_SHEAD	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 FCI_SCOPY	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
	 isinf	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Float.c
	 flt_round	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Float.c
	 flt_floor	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Float.c
	 flt_ceil	 in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Float.c
Building CASM file
Memory Usage Report
RAM available:368 bytes, used:37 bytes (10.1%), free:331 bytes (89.9%),
Heap size:331 bytes, Heap max single alloc:110 bytes
ROM available:8192 words, used:133 words (1.7%), free:8059 words (98.3%)
success
Return code = 0
FINISHED
Are you running the same version as me = 5.5.2.1 (30.01.2013)?
waligator
Post by waligator »
As well as windows 10 64bits. Same version Flowcode (30.01.2013). Yesterday everything worked very well and after the update of windows, nothing.
waligator
Post by waligator »
Do I have to update Boostc ?
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
This sounds like an issue with a firewall (Windows Defender?) or anti-virus program preventing the launch of BoostC. Does the same problem occur if you boot the computer in safe mode? And are there any logs for the firewall (etc) that might show what the problem is?
There may also be a way of "white-listing" the BoostC compiler so it is not being blocked.
waligator
Post by waligator »
the compilation runs in safe mode. I found the culprit who is the Malwarbytes program. I had to disable a protection layer but I can compile my program again in Flowcode.
Thank you for your help
Post by Steve »
Excellent - glad you found the issue and thanks for letting us know.
