BL0080 problem
fotios
Has thanked: 109 times
Been thanked: 117 times
BL0080 problem
Post by fotios »
Hi everyone
I just checked the new E-blocks2 BL0080 PIC multi-programmer with the BL0114 combo board.
I compiled a small fcf just to check the 4X20 LCD display of BL0114.
With the stocked P16F18877 the code is normally compiled without errors and the LCD works as in the code.
I replaced the P16F18877 with a P16F1937, after with a P16F1939 and later with a P16F1789 and in all cases, during compiling, I received this message from the compiler:
File sent with 1 warnings:
  1: Flash memory not verified - may be due to code protect
The code is not compiled in any of the 3 micros.
Here the simple fcf:
LCDtest.fcfx
(10.51 KiB) Downloaded 520 times
Thanks for any help
Best Regards FOTIS ANAGNOSTOU
fotios
Re: BL0080 problem
Post by fotios »
Please note that:
I have compiled with success in the past an FCF code for 4X20 LCD display, using the FC v7 and as target either a P16F1939 or a P16F1789 but as a programmer I used my old EB-006 board.
I think the problem is on the side of BL0080 and not on BL0114.
Re: BL0080 problem
Hmm it looks like the 16F1937 chip is being detected and erased but the program is not being loaded.
Investigating this now as it certainly used to work.
fotios
Re: BL0080 problem
Post by fotios »
Any good news to solve the BL0080 problem?
fotios
Re: BL0080 problem
Post by fotios »
After updating the FC7 LCD component with the new LCD.fcpx, neither BL0080 works right now.
Please note that I had no problem with it and P16F18877 so far.
See how it prints
Here my simple fcf to test LCD
LCDtest.fcfx
(10.56 KiB) Downloaded 535 times
Re: BL0080 problem
Sorry for the problems. I've reverted the LCD component back to how it was originally and this has fixed the problem but causes the problem to re-appear on the ST-ARM.
Here is the original component file to allow you to switch back to get the PIC working again.
LCD.fcpx
(7.54 KiB) Downloaded 497 times
Re: BL0080 problem
New universal fix posted here.
viewtopic.php?f=2&t=20040&start=25#p88651
