Hi Benj,
Working on my project I have to use a gps, but I've noticed that in V8 flowcode the TX pin does not exist in the properties of the GPS component and I do not understand why. Can you help me?
pin TX en GPS
Re: pin TX en GPS
GPS modules usually just output the position data to their TX pin which is connected to the RX pin of the microcontroller and no data is required to be transmitted back to the module.
Your module may be a special case if you need to send something to it. Which GPS module are you using?
casicalvo
- Flowcode v5 User
- Has thanked: 3 times
- Been thanked: 1 time
Re: pin TX en GPS
Hi benj. Ok, thanks.
hello benj OK thanks
I attached photo of the gps with which I am working, I also attach capture of the error that gives me when compiling and the file that I use and that works perfectly with my previous version of flowcode. Thanks in advance
- gps_webmatel.fcfx
- (16.81 KiB) Downloaded 483 times
- ERROR GPS.jpg (238.4 KiB) Viewed 15075 times
- GPS.jpg (144.67 KiB) Viewed 15075 times
Re: pin TX en GPS
Many thanks for letting us know of the problem.
I have replicated the issue using your program and have now been able to fix the problem. I'll push the component fix to the updates system later on today.
