Compiler error PIC24FJ128GA204 and 24EP512GU810
A forums to allow bugs and problems with Flowcode v7 to be reported and resolved.
patrick schoon
Has thanked: 7 times
Been thanked: 13 times
Post by patrick schoon »
Please check the compiler support for the PIC128GA204 and PIC24EP512GU810.
On both i get an error.
No complex data writen, just a blinking led in a loop..
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat "test" "D:\ELECTR~1\Flowcode\MACROS~1\" "24FJ128GA204"
Launching compiler...
D:\ELECTR~1\Flowcode\MACROS~1>xc16-gcc -c -mcpu="24FJ128GA204" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\FLOWCO~2\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\FLOWCO~2\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "test".c -o "test".o
Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key.
test.c:32:22: fatal error: p24Exxxx.h: No such file or directory
compilation terminated.
Error returned from [xc16-gcc.exe]
Completed compilation, return = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat reported error code 1
FINISHED
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Compiler error PIC24FJ128GA204 and 24EP512GU810
Post by QMESAR »
Both these chips compile just fine fore me in both FC7 and FC8
Hi Patrick,
Can you confirm if the "p24Exxxx.h" file exists in the following directory.
C:\Program Files (x86)\Flowcode 7\compilers\pic16\support\PIC24E\h
If the file is there then it may be worth trying this workaround.
http://www.flowcode.co.uk/faq/index.php? ... artlang=en
If the file is not there then it may be worth uninstalling and reinstalling Flowcode.
patrick schoon
Guys,
Thanks for the quick help.
The workaround of re-installing and the register modification did work. All fine now. :D
