Please check the compiler support for the PIC128GA204 and PIC24EP512GU810.
On both i get an error.
No complex data writen, just a blinking led in a loop..
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat "test" "D:\ELECTR~1\Flowcode\MACROS~1\" "24FJ128GA204"
Launching compiler...
D:\ELECTR~1\Flowcode\MACROS~1>xc16-gcc -c -mcpu="24FJ128GA204" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\FLOWCO~2\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\FLOWCO~2\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "test".c -o "test".o
Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key.
test.c:32:22: fatal error: p24Exxxx.h: No such file or directory
compilation terminated.
Error returned from [xc16-gcc.exe]
Completed compilation, return = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat reported error code 1
FINISHED
Compiler error PIC24FJ128GA204 and 24EP512GU810
patrick schoon
- Has thanked: 7 times
- Been thanked: 13 times
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Compiler error PIC24FJ128GA204 and 24EP512GU810
Both these chips compile just fine fore me in both FC7 and FC8
Regards QMESAR
Regards QMESAR
Hi Patrick,
Can you confirm if the "p24Exxxx.h" file exists in the following directory.
C:\Program Files (x86)\Flowcode 7\compilers\pic16\support\PIC24E\h
If the file is there then it may be worth trying this workaround.
http://www.flowcode.co.uk/faq/index.php? ... artlang=en
If the file is not there then it may be worth uninstalling and reinstalling Flowcode.
patrick schoon
Guys,
Thanks for the quick help.
The workaround of re-installing and the register modification did work. All fine now.
