Compiler Error using RS232
CSM2711
Has thanked: 1 time
Been thanked: 9 times
Post by CSM2711 »
I try to use the RS232 componentwith my PIC16F18313, but i get the following compiler Error:
366: tris |= (1 << (0));
^ (192) undefined identifier "tris"
(908) exit status = 1
Please tell me if I'm wrong, or if it's a general problem with the RS232.
Tankks Marcel
BUGRS232.fcfx
(8.18 KiB) Downloaded 199 times
Re: Compiler Error using RS232
The problem is because the RX pin is unconnected even though it is not being used it need to be connected.
Set the UseRx property to true, then connect the RX pin to a valid pin and then set the UseRx property back to false and it should compile correctly now.
CSM2711
Has thanked: 1 time
Post by CSM2711 »
Thanks a lot, now it is compiled.
But I get no output on PIN RA0.....
No Data and no voltage (measured with oscilloscope)
Any one an idea????
CSM2711
Has thanked: 1 time
Post by CSM2711 »
A short update:
sending a char via the UART (CAL) will work!
sending a number via UART component dosent work.
Maybe there is a problem with the component?
CSM2711
Has thanked: 1 time
Post by CSM2711 »
Am I really the only one who has this problem?
Or is there only this problem with the PIC16F18313?
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
Please try the updated CAL file, to go into C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC
Auto update will be updated soon.
Thanks for spotting this.
PIC_CAL_UART.c
(36.05 KiB) Downloaded 189 times
