I try to use the RS232 componentwith my PIC16F18313, but i get the following compiler Error:
366: tris |= (1 << (0));
^ (192) undefined identifier "tris"
(908) exit status = 1
Please tell me if I'm wrong, or if it's a general problem with the RS232.
Tankks Marcel
Compiler Error using RS232
Re: Compiler Error using RS232
The problem is because the RX pin is unconnected even though it is not being used it need to be connected.
Set the UseRx property to true, then connect the RX pin to a valid pin and then set the UseRx property back to false and it should compile correctly now.
- Has thanked: 1 time
- Been thanked: 9 times
A short update:
sending a char via the UART (CAL) will work!
sending a number via UART component dosent work.
Maybe there is a problem with the component?
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Please try the updated CAL file, to go into C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC
Auto update will be updated soon.
Thanks for spotting this.
- PIC_CAL_UART.c
- (36.05 KiB) Downloaded 188 times
