PICKit 3 compiler file
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Post by Jan Lichtenbelt »
Does someone has the compiler file (.fcs) for PICKit 3 MAPLABX for me?
Kind regards
Jan
Re: PICKit 3 compiler file
Hi Jan,
This works for me every time.
Use IPE version
Hi Jan,
It's better to do the change yourself as Martin pointed out. Simply because the path to the MPLABX IPE changes with each released version number and that's if your using the default location which a lot of people don't.
Jan Lichtenbelt
It took a while. That means the compiler and linker/assembler will be the same. And the default compiler must be made active for this (new) PICkit3 complier option.
Connecting the PICkit3 to the PC shows the power on and the active LED is on also.
Loading the flowcode file into my 16LF1847 microchip shows an error "Programmer not found" with error code 3 or 9.
Some idea what the reasons can be?
Kind regards
Jan
PS. Using the stand alone PICKit3 programmer in combination with the .hex file recognise the microchip and works fine.
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi all.
Just as an info not sure if this is Jan's problem however since MPLABX5.x the IPE.exe has moved location it is now in a sub folder called Platforms
the path is some thing like this C/programs(86) MPLABX/Platforms/IPE/ipe.exe
This caught me out last week and FC complains Programmer not found :D
Hi Peter,
good point.
Seems like Wiki entry could do with updating.
QMESAR
Post by QMESAR »
Yea I have been using the settings as per wiki for a long time and never failed me but upgrading to MPLABX 5.1 catched me out until
I looked and found the new platforms folder in MPLAB :D
Have great weekend
Jan Lichtenbelt
Hi Peter and Martin
My location is still:
C:\Program Files (x86)\Microchip\MPLABX\v5.10\mplab_platform\mplab_ipe\ipecmd.exe
And the problems are still left.
Kind regards
Jan
Have you tried programming with IPE first?
You could try with the PICkit3 unplugged, With reset button pressed in, pug the programmer back in.
Have you got power going to the target device during programming?
Jan Lichtenbelt
I tried IPE, but up to now it is not clear how to get that software work correctly.
The USB has been removed and plugged in again. Power and äctive" LEDs are on.
test_PICkit3.msg.txt
(2.04 KiB) Downloaded 357 times
Kind regards
Jan
QMESAR
Post by QMESAR »
Hi Jan.
In my humble opinion I am sure your path to the ipe is incorrect :D
with me there is no mplab_ipe
it is MPLAB/platform/ipe/ipe.exe
but every machine is different all I can say I am sure it is the path set to the ipe SW
Hope you get it right
I would have thought using browse within programmer location of Flowcode would be better than typing or copy and paste?
Jan Lichtenbelt
Hi Martin and QMESAR,
Probably to due an newer version of MPLAB, the directory is now:
ipecmd directory V5.10.jpg (37.46 KiB) Viewed 7228 times
Kind regards
Jan
Jan Lichtenbelt
I tried it first on my Laptop (see messages above) and now on my PC. A different error message, but with the same result. On this moment I will stop using the PICkit 3. All of you, thanks for helping
Kind regards
Jan
Hi Jan,
No problem.
When you are ready to try again, I will take you step by step on programming with PICkit3 Via IPE
Once that is working flowcode should work.
